headlight bucket question
Old Feb 8, 2006 | 11:29 PM
mark914's Avatar
mark914
on what years are the are the headlight buckets the same? Is 53 - 55 the same,and '56 is different? are 48-52 the same as 53 -55?
just curious...going thru boxes of parts.
Thanks
Mark
Old Feb 9, 2006 | 01:00 AM
F250Rob's Avatar
F250Rob
The parts catalogs call the headlight buckets the "headlamp assembly less bulb and wiring".
The text catalog lists one part number for 1948-55 (B8J 13008-A) and a different one for 1956 (B6C 13008-A).
But the illustrations catalog shows one 48-56 "typical" headlamp assembly.
The retaining ring that sits in front of the bulb and holds it down was the same from 48-56.
I'm not sure what the difference was in the two bucket assembly part numbers.
Could be a 6V/12V thing...different wiring leads and bulbs.
Old Feb 9, 2006 | 09:01 PM
grncoup's Avatar
grncoup
the difference is the '48-'55 style mount "outside" the grille. the '56 mount "inside" the grille. the outside edge of the '56 is smaller than the earlier buckets. also there is some difference in the springs that hold the bulbs in place.
Old Feb 9, 2006 | 09:41 PM
kdmcinnes's Avatar
kdmcinnes
53-55 are outty's and 56 are inny's
Kyle
Old Feb 9, 2006 | 10:04 PM
mark914's Avatar
mark914
Thanks for the responses fellas! Now i know what i got.
Old Feb 10, 2006 | 03:38 PM
papabills54's Avatar
papabills54
I made the outty's in to inny's by grinding the outer lip and droping the assy into the grill.
clintonvillian
Feb 3, 2014 09:25 PM
53OlderThanMe
17
Feb 23, 2009 07:01 AM
houghda
18
Jun 22, 2007 10:41 AM
delaney
Sep 19, 2006 03:35 AM
Jun!or
Apr 17, 2002 01:25 PM
