Tranny Dipstick Problem
Old Feb 8, 2006 | 10:51 PM
tuekwik's Avatar
tuekwik
Question Tranny Dipstick Problem
Just replaced my E4OD with a C6 on my 1991 F150 351W, the dipstick is in a different location. Use to sit on the passenger side of the engine now it is in a very bad spot behind the intake. Today I picked up the truck from the shop and drove it for 1-2 miles and wouldn't shift, found out that it was leaking tranny fluid from were the dipstick inserts into the tranny. Any ideas how to fix this. THANKS!!!
Old Feb 8, 2006 | 11:52 PM
53fatfndr's Avatar
53fatfndr
Lokar makes a nice flexible tranny dipstick. You can mount the top part just about anywhere. I mounted my handle part to my firewall in my '53.
http://www.lokar.com/
If the dipstick insert is just leaking, there should be an o-ring around the insert as well, it might need replaced. But if it's bent, which is causing it to leak, the Lokar dipstick may be the way to go.
