Need some help guys!
Old Feb 8, 2006 | 06:37 AM
tondalynn88's Avatar
tondalynn88
Hi there- I'm new here and looking for a bit of help or ideas as to what can be wrong. I have a 93 F150, went to warm her up this morning, put the key in, I couldn't even turn the key over. It's like I have the wrong key in the ignition. Checked to be sure she was fully in park and she was, tried my spare key, nothing. The chimer that tells me my key is in the ignition goes off but it just won't let me turn the key over. I have no idea what is going on. Any ideas??
Old Feb 8, 2006 | 06:42 AM
frederic's Avatar
frederic
If it is the correct key (Hey, we've all had mornings like that) more than likely the steering wheel is pushing hard against the locks and therefore the ignition lock is being "bound".
Put key in, turn wheel side to side a little bit, then turn ignition key while wiggling the wheel.
Best it turns no problem.
Old Feb 8, 2006 | 06:58 AM
tondalynn88
Tried that already this morning, ended up locking the wheel up. Now I have no slack in the wheel.
Old Feb 8, 2006 | 09:09 AM
Kista20's Avatar
Kista20
I don't know what it's called but mine is bad for the "chrome ring" around where you put the key in it will get turned and the key won't go in properly and you have to align it up. I'm sure thats the same problem that mine does occasionally. Try pushing in the key while twisting the ring back and forth with your left hand to line it back up.
Old Feb 8, 2006 | 09:28 AM
tondalynn88
OK, I will try wrestling with it some more when I get home from work. Had to ride into work with the hubby this morning.
Old Feb 8, 2006 | 10:34 PM
skrappy's Avatar
skrappy
you probably need a new tumbler, which is what the chrome thing is called, and they seem to be a problem on that generation, ive replaced them on my 93 f150 my brothers 95 f150 and my 89 f350... its really easy to do and costs about 30 bucks from your local ford dealer.
Old Feb 9, 2006 | 08:58 AM
Livewire88's Avatar
Livewire88
Hey there is a recall on my 88 ford truck for the switch. There going to put one in for me for free check on that.
banshee_man_96
Nov 22, 2018 07:20 AM
Blythewoodjoe
1997 - 2003 F150
Mar 11, 2013 09:56 AM
DOC1KOC1
Aug 4, 2011 06:56 PM
cobrarep
Aug 3, 2008 01:13 PM
sportyg
May 24, 2006 11:27 PM
