Killing me Softly
Old Feb 7, 2006 | 09:20 PM
Dooky's Avatar
Dooky
Unhappy Killing me Softly
I own a 82 with a 351 5.8 with Carb, Duraspark (not sure what color, was replaced) bought from a friend sight unseen, when i picked it up was in great condition, but his dad tore apart the wiring for the starter relay, the Haynes book diagram doesn't match what I got, i got lucky and got it to run, but now here's the problem..runs for 3 to 5 minutes then dies, and starts only if it wants to..new plugs, new battery(sluggish after dying), new starter, new coil, but will run with the battery cable disconnected...my non pro diag is that the wiring is somehow not allowing the alternator to charge the battery, and run until the battery dies, but then it will turn over and over without spark until finally it wants to...any suggestions?????
Old Feb 7, 2006 | 10:36 PM
Larry_the_handyman's Avatar
Larry_the_handyman
Have you tried replacing the ignition control module? If someone shorted out a couple wires while redoing the starter relay, it could have fried the ICM. A charged battery will run a truck for quite some time without the alternator. Have you tried running with jumper cables to another running vehicle? That would overcome the alternator issue entirely.
Old Feb 8, 2006 | 07:21 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Dooky to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 8, 2006 | 09:54 AM
subford's Avatar
subford
I think you might have low compression, do a compression check. I think it runs until the choke opens and then it dies. If you need a wiring diagram email me with your email address.
Old Feb 8, 2006 | 07:22 PM
Dooky's Avatar
Dooky
Thanks for the quickness
I think that the problem is likely the ICM, but i have no idea which is the right one to put in there, IT STARTED this morning , but who knows why?? I believe that someone has replaced the ICM with a questionable one, also I am in desperate need of the wiring diagram, but I can't send out an email until my probation period here is up..if you can send it to me at jsph4@hotmail.com
Old Feb 8, 2006 | 07:39 PM
subford's Avatar
subford
Originally Posted by Dooky
I think that the problem is likely the ICM, but i have no idea which is the right one to put in there, IT STARTED this morning , but who knows why?? I believe that someone has replaced the ICM with a questionable one, also I am in desperate need of the wiring diagram, but I can't send out an email until my probation period here is up..if you can send it to me at (Click Here to find out why email addresses are removed from posts.)
I emailed you my email address.
Old Feb 13, 2006 | 07:37 PM
Dooky's Avatar
Dooky
thanks SUBFORD,
you were a great help, i changed the EEC under the seat and it runs like a champ
Rusty Axlerod
Feb 28, 2023 11:19 AM
harleymc
Nov 22, 2016 02:17 PM
whimsy
29
Sep 28, 2016 05:44 PM
jayro88
Jul 16, 2016 11:47 AM
BigBlocker0248
May 14, 2016 06:09 AM
