302 ??
Old Feb 7, 2006 | 08:51 PM
usmashme's Avatar
usmashme
302 ??
I just looked at a 91 f150 4x4 the motor is smoking my ?
is I have a 87 302 out of a merc. wagon with 39,000 mile
what is different from the truck motor to the car motor
what am I going to have to change to put the car motor in
the truck any help would be great
Rob
Old Feb 7, 2006 | 09:28 PM
Putt's Avatar
Putt
You will need to change all the external dress from the '91 to the '87. ie. the oil pump pickup tube(with the stud for the main cap support), the oil pan, valve covers, timing cover and water pump, intake manifold, and likely a few other items someone else will remember. You will basically be using only the long block portion of the '87 motor-block and rotating assembly, heads and valve train.
Old Feb 8, 2006 | 07:22 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Rob to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Rij1
Mar 6, 2017 10:02 PM
Highriser4
1978 - 1996 Big Bronco
Jan 4, 2013 09:02 AM
nitronigs
Mar 29, 2011 08:01 PM
david00f150
May 28, 2010 10:01 PM
Ford_By_Four
Oil & Lubrication
Jan 18, 2005 01:13 AM
