safe levels?
Old Feb 11, 2006 | 10:04 AM
Fords4Me's Avatar
Fords4Me
Originally Posted by a94cobra
So if we just cap the red line on both ends, no blow off of turbo boost. Any side effects?
Just cap the one side. The turbo will be able to build more boost, and if you have a tune installed the wastegate won't open, and if you then get to 25psi or so the computer will defuel the engine to reduce boost and set off the CEL. If you have no tune or are runnng a tow tune you should have no issue. Worst case is the light.
Old Feb 11, 2006 | 10:14 AM
aklim's Avatar
aklim
Hink10, Did you get the one for the excursion? It shoud be S6204 ending in AL, 409 or 304. If so, shouldn't it have fit without cutting?
Old Feb 11, 2006 | 10:18 AM
hink10's Avatar
hink10
Yeah, it was the Excursion exhaust. I could have left it, but the tip stuck out farther than I would like. Without the tip, it was about right.
Old Feb 11, 2006 | 01:49 PM
a94cobra's Avatar
a94cobra
So no need to do the mod if I have the truck chipped or programmed?
