Converting points to electronic igntion
Old Feb 7, 2006 | 08:03 PM
cwooten63's Avatar
cwooten63
Planning on getting parts from the junk yard to convert my 76 f100 with 302 to electronic ignition. I was told to tell the person there just exactly what i wanted to do, and someone would know what I was talking about. I thought it would be better to ask you guys first if there is anything I should know before I do this, such as, does everything need to come from a specific make/model ford, or does this matter... anything else I should look for? Thanks for your time...
Old Feb 7, 2006 | 08:06 PM
ford390gashog's Avatar
ford390gashog
i assume you want the duraspark setup? have you considered somehting else? i went with the xr-i setup from crane cams. www.summitracing.com
Old Feb 7, 2006 | 08:31 PM
Putt's Avatar
Putt
You want to get a blue grommet module and the distributor and ALL the wiring harness in between those items. They would not need to be from one vehicle as long as the module matches, the basic parts(harness, connectors, dist.) are the same.
Old Feb 7, 2006 | 09:22 PM
cwooten63's Avatar
cwooten63
ford390gashog
yes, I have thought about just doing a conversion as well. thanks for the link.
Putt
this is what I thought. Glad to see I was on track. Thanks.
Old Feb 8, 2006 | 10:48 AM
TigerDan's Avatar
TigerDan
I have even installed all the Duraspark components into a points distributor, it's not difficult. Requires minor cutting in the housing to make the round hole where the wire goes through into a slot for the Duraspark grommet, everything else fits right in. But the 302 Duraspark distributor is very common and easy to find, so you shouldn't have to go to that extreme.
As Putt said, get the module with the blue grommet. It's probably the most common one and best for all-around general use and performance.
Wiring it into the vehicle is simple. It's all basically self-contained if you get the harnesses, and you only need to hook up 2 wires. Let me know if you need wiring diagrams, I have several.
Old Feb 8, 2006 | 07:23 PM
cwooten63's Avatar
cwooten63
TigerDan
thanks for the info. wiring diagrams wouldn't be turned down as a just in case measure.
Old Feb 8, 2006 | 08:26 PM
TigerDan's Avatar
TigerDan
Here's a good one I came across recently:
SUPERDUTY OUTLAW
55
Dec 12, 2017 06:20 AM
HANDSOME
Engine Swaps
Dec 15, 2015 11:38 PM
MN1967
16
Jun 7, 2013 07:45 AM
mla
Feb 1, 2009 09:51 PM
john1245
Nov 3, 2000 03:48 PM
