Sponsored by: Auxito
Spark knock?
Old Feb 7, 2006 | 05:52 PM
mk-cats's Avatar
mk-cats
Spark knock?
Hi, got my 01 F150 supercrew in Oct. 05, noticed a noise upon acceleration.
Could this be what I've been told as spark knock?
Should I be worried & what can I do about it?
TIA, Denise
Old Feb 7, 2006 | 05:56 PM
andym's Avatar
andym
It could be, and if it is, you should be concerned about it. If you leave it for too long, you'll ruin the motor.
What does it sound like?
Old Feb 7, 2006 | 06:04 PM
Beast12's Avatar
Beast12
Welcome to FordTrucks.com! We are the Internet's Premiere Resource for all things Ford Truck and SUV related!
We are happy to have you! There is a ton of great info on this site. But, before you go snooping around there are a few things you need to do first.
1) Want to meet or talk to other members in your area? There are Provincial, State and International Chapters located near the bottom of the main forum page.
2) Before you post a thread asking a question be especially aware of where (what forum) to place it in. FTE is HUGE! Make sure you read the Read First: at the top of the forum before you go posting.
Thread moved to 2004-2006 F-150 forum.
3) And finally you should review the Guidelines. They will kind of give you an idea of what is and isn't allowed on this site ("The Rules").
And that is it. I hope you enjoy the FTE "Experience"! This is a great place and we have lots of fun while exchanging valuable info. If you have any questions or problems do NOT hesitate to contact me. Just click my username then send me an email.
-Matt
Old Feb 7, 2006 | 06:21 PM
jim henderson's Avatar
jim henderson
Tell us more about the noise.
Spark knock comes in many different levels and may or may not be a problem.
In general terms, ping is a light knock. Knock is midway in sound level and Detonation is very bad. It is hard to describe the ligther versions of knock but when you hear them and have experience you can tell the difference.
A lot of engines, especially if they haven't had the "Carbon blown out of them" ie driven hard once in awhile, can develop a ping. Also gas that is marginal for the temperatures and load you are hauling can cause a gentle ping. Most magazine articles say occasional light ping is just an indication that the engine is running at optimum air fuel mix for economy. Normally cooler weather or a slightly better grade of gas will get rid of ping. Ping is usually not heard or occasionally audible. A gentle occasional ping is not considered bad. Ping is like a light tapping on the piston crown.
I sometimes had ping in hot weather up a long hill with my AC on, in 5th gear in an 89 SHO that had something like 10.5:1 compression, running 87 octane gas. Switching to 89 or better got rid of the ping. In winter 87 ran fine with no ping at all. Ditto my 94 F250 hauling a trailer. Hot weather, long hill, heavy load, 87 octane=ping, so I used 89 and 91 in summer while towing.
Knock is usually pronounced and fairly obvious. If you ever heard a gas engine "run on" or diesel after shutting down, that is an obvious sound of knock. Also a truck hauling a heavy load up a mountain in hot weather with low octane will have a noticable knock. Knock is damaging and eventually you will melt a piston, hammer the bearings or break something else. Knock is like hammering on the piston crown.
Detonation is very violent and sometimes sounds explosive out the tail pipe, not quite like a backfire. An engine detonating will ruin itself pretty quick.
So tell us what your noise sounds like and when does it happen? Include, engine, tranny, gears etc. Tell us the temperatures, how much load you are haulling and does it only do it in certain conditions?
Most modern engines have knock sensors and the computer usually does a good job of controlling knock. You should almost never hear knock(and only briefly) and only rarely hear ping. This assumes you are running with gas that is up to spec for your engine.
Good Luck,
Jim Henderson
Old Feb 7, 2006 | 07:05 PM
Monsta's Avatar
Monsta
Sit. Stay.
WHY? She has an 01.
Old Feb 7, 2006 | 07:12 PM
Beast12's Avatar
Beast12
Oops. I overlooked the 01 and saw the Oct 05 and put two and two together and got 3.
-Matt
Old Feb 7, 2006 | 07:15 PM
WhëëlMå1's Avatar
WhëëlMå1
You guys wanted this in the Audio/Video forum, right?
