Sponsored by: Auxito
anyones windows done this??
Old Feb 7, 2006 | 05:00 PM
1BadKingRanch's Avatar
1BadKingRanch
on my 01' screw, when iam going faster then 50 mph, and roll the window down, then roll it up, it wont go all the way up, leaves alittle space to where u can hear air still. but when i slow down, it closes all the way... i think the wind is pushing the trim closed and not letting it go in...iam goin to take it in to dealer sometime...
I know on my 03' i had the window trim was different then on my 01'....
Old Feb 7, 2006 | 05:16 PM
bigdaddyII's Avatar
bigdaddyII
The last cars I had with power windows that done that, the windows wouldnt close after a while when it wasnt moving and than it would only go up part of the way and than it would fall for no reason. The track would break. I would definatly take it in to the dealer and nip that problem in the bud.
Old Feb 7, 2006 | 06:35 PM
Johns9163's Avatar
Johns9163
This is a typical problem and you can easily do it yourself. Put the window half way down, grab with hand across top of window, try to move glass forward and aft, I bet it moves quite a bit and you will be surprised on how much it does and you never knew. This is what is causing your window issue. Remove the door panel and take a peak at the point that the glass is attached and look at the track movement itself. There are a couple of things in there that will cause the problem. Mine was the point the glass connects at the track. Hope this helps...
