4.2 E-150 Runs Rough
Old Feb 7, 2006 | 03:34 PM
mmilukas's Avatar
mmilukas
Angry 4.2 E-150 Runs Rough
E-150 Van, 4.2 engine 155,000 all highway, serviced regularly. Put plugs, wires, coil, and O2 sensors in, all motorcraft. From a dead stop has all kinds of power, transmission shifts through and between 40 and 50 mph starts to buck and miss.
Over 50 can drive it 85. This thing has been laid up for 3 months. I can't figure it out. Ford tech says i need an engine, at the tune of $6,000, I went duh.
So I really need some expert advice.
Thanks
Mike
Old Feb 11, 2006 | 11:24 PM
Tstorms's Avatar
Tstorms
Check the mass air flow sensor It could be dirty or bad. Also check fuel pressure. You didnt mention if it has any fault codes. If it has a lean code I would think the mass air sensor is the possiable problem. Did the dealer give any reason for saying the engine is bad. Im a ASE master certified mechanic If you have any other questions Email me.
asemec@msn.com
RotGrubestier44
3.8 & 4.2L V6
Feb 22, 2011 03:20 PM
302lx
3.8 & 4.2L V6
May 16, 2010 01:52 PM
Tom Casey
1997 - 2003 F150
Feb 13, 2000 03:46 PM
