vent window pivot spring
Old Feb 7, 2006 | 02:15 PM
ken selvy's Avatar
ken selvy
Question vent window pivot spring
I am ordering a pivot spring from lmc , because I broke my vent window pivot on drivers side . Is this the right part to fix this ? Is it hard to replace ? What is the best way to fix this ? Thanks for any help . KFLORD77.
Old Feb 7, 2006 | 08:41 PM
Mil1ion's Avatar
Mil1ion
You have to remove all the door glass and the complete vent frame.
Old Feb 7, 2006 | 09:35 PM
deisele75's Avatar
deisele75
Be super careful not to wreck your paint while your taking the frame out. Once you get it out of the door you can bang the retaining pin out with a small finishing nail.
Old Feb 8, 2006 | 12:56 PM
ken selvy's Avatar
ken selvy
Thanks, since the truck is primered no worries , I am still wondering if I bought the right part from lmc , it is called a pivot spring and does it have the retaining pin? KFLORD77
Old Feb 8, 2006 | 02:18 PM
deisele75's Avatar
deisele75
You can reuse your old one
Old Feb 8, 2006 | 03:39 PM
ken selvy's Avatar
ken selvy
I broke it , thats why I asked if that was the right part from lmc pivot spring . If it comes with pin lmc couldnt tell me .
Old Feb 8, 2006 | 05:57 PM
STGFordCrazy04's Avatar
STGFordCrazy04
LMC couldnt tell you because you probably talked to some chick who couldnt pick a 73-79 truck out in a line up of all rice burners much less tell you if youre buying the right part to fix your problem. If what you bought doesnt have the pin let me know and Ill send you one.
Old Feb 8, 2006 | 06:08 PM
Mil1ion's Avatar
Mil1ion
You are talking about the vertical tension placed on the vent window where it swivels to keep it from free-wheeling open & closed ...correct ?
You may be able to get at it with a deep socket & a ratchet.
None of the books or CDRoms I have ...show an illustration of it.
I just know how it assembles.
I can take a pic of the complete assembly if you need one as I have a couple in the garage
Old Feb 8, 2006 | 08:26 PM
deisele75's Avatar
deisele75
I bought new vent window handles from LMC and they came with everything I needed.
Old Feb 8, 2006 | 09:38 PM
Mil1ion's Avatar
Mil1ion
I don't think he is talking about the closure handle
Old Feb 8, 2006 | 10:36 PM
deisele75's Avatar
deisele75
Oooooooh.... I know what your talking about now. I thought you were talking about that little spring that pushes on the lock pin on the window handel. Never mind what I said in post #3
That would be a nightmare trying to reach up there with two hands and get all the washers in place, while trying to set the glass back in. The easiest way to do it would be the way Mil1ion said in post #2
Old Feb 15, 2006 | 01:01 PM
ken selvy's Avatar
ken selvy
Question vent window pivot pin
I posted before but no luck on help , I bought the pivot spring from lmc but no pivot pin came with . Does anyone know if the pivot pin is connected to the vent frame? Mine is broke off and I can push the window in at the bottom and see the broken pivot pin still in place . Can I take the frame off and take the broken pivot pin out and have it welded to the frame? Then put it back together? Thanks for any help . KFLORD77 . Also bought new door switches from lmc and my passenger side works again , turns dome light on when door is open , the little things in life make me so happy .
Old Feb 15, 2006 | 01:46 PM
Torque1st's Avatar
Torque1st
Posting Legend
Thread merged.
You need an entire frame. The broken pin would be difficult to repair properly. It might be repairable tho... -just have to take it to a welder. Sorry we can't tell you more but we are not looking at the broken parts. Even pictures don't help in this situation.
Old Feb 15, 2006 | 03:40 PM
Mil1ion's Avatar
Mil1ion
There should be a slotted keeper washer to hold it up against the pin when the spring is installed.(much like a brake shoe hold down spring system)
I don't see why someone couldn't braze the pin back where it should be.
Old Feb 15, 2006 | 03:46 PM
Torque1st's Avatar
Torque1st
Posting Legend
It kind of depends on how much metal is left and it's condition.
