Offroad & 4x4
Hey, Ivan
Old Feb 7, 2006 | 12:53 PM
Dustin_86's Avatar
Dustin_86
Question Hey, Ivan
I have a AC compressor on my 78 that is not being used and a buddy told me that I could make a toggle switch for power to the compressor, and get a air hose and a chuck. Will I have onbord air? How many SI? He said I would be able to air tires , but not run an impact..... So i'll asume 100psi.
Dustin
Old Feb 7, 2006 | 12:58 PM
fishmanndotcom's Avatar
fishmanndotcom
i'm not ivan (obviously) but that will only work if you have a york or sanden. you COULD use fords a/c compressor but there is oil issues
-cutts-
Old Feb 7, 2006 | 01:06 PM
Dustin_86's Avatar
Dustin_86
Oil issues???? It was an dealer AC so would it have the compressor you mention. What about just squirting compressor oil for my air compressor ever 20 hours or so?
Old Feb 7, 2006 | 01:13 PM
ivanribic's Avatar
ivanribic
It should be a York compressor. It will have an oil fill plug on it so you just need to make sure the oil is topped off. The other style that cutts mentioned is lubed by the freon I believe, and they'll seize up if you're using them as an air compressor. The York compressor can charge 150 psi pretty easy if you want. To run an impact you just need an air tank. It's not the pressure so much that's the issue as the volume so if you have 5 or 10 gallons storage you're set. You'll also want a pressure switch on your tank to turn off the compressor when it reaches your desired pressure, otherwise it would just keep filling until something blows up. You can buy the pressure switches at any air/pnuematic shop for cheap. It's also a good idea to run an oil trap on the pressure line to the tank, York compressors seem to leak a fair amount of oil past the seals and you don't want that crap building up in your tank.
Old Feb 7, 2006 | 01:18 PM
fishmanndotcom
yea, the york and the sanden are the only 2 i know of that dont get lubed from the freon.
here is some info on the yorks http://www.kilbyenterprises.com/york.htm
ivan.... did you ever get yours mounted? i am about to mount a york on my PSD for some air horns and bags
-cutts-
Old Feb 7, 2006 | 01:43 PM
ivanribic's Avatar
ivanribic
Nope. I decided to ditch that whole plan because I really don't need the OBA that bad. I have an electric compressor for my ARB's and that's it. I'll do a York compressor when I get around to the trail rig.
Old Feb 7, 2006 | 04:16 PM
chrono4's Avatar
chrono4
trail rig, havent heard about that one, whats up?
Old Feb 7, 2006 | 05:27 PM
Flareside94's Avatar
Flareside94
Didn't you know? The Cap'n is a REALLY expensive mall cruiser. He's got better plans for next time.
Old Feb 7, 2006 | 06:24 PM
ramboss429's Avatar
ramboss429
I used the AC compressor out of my '85 F150 after I rolled it in my shop for 5 years before retiring it a few months ago when I bought a new Craftsman air compressor. All I did was squirt some oil in it when I felt like I should treat it right. It worked good and never had a problem with it. I will probably use it on my truck someday for an air compressor, and use my bumpers as tanks
Old Feb 7, 2006 | 10:47 PM
my79f's Avatar
my79f
where would the name of the a/c compressor be located
Old Feb 9, 2006 | 08:52 AM
Dustin_86's Avatar
Dustin_86
Mine has no tag, but had the ID numbers for the 10 CI York. it was on the top next to the hose C 10, then a serial number. C-10 is the bad boy I think! What would I use to connect the Discharge side to an air line it, will not fit a quick disconnect, Do I need to change the compressor oil?
I saw the two oil plugs
Old Feb 9, 2006 | 10:33 AM
s8whiskey's Avatar
s8whiskey
why couldnt you just pipe a line to the compressor and run it from the engine oil pump?
Old Feb 9, 2006 | 10:34 AM
fishmanndotcom
dustin... go to that site i posted above and you will find more info than you ever care to know about that compressor! lol
be careful though, you might just learn something
-cutts-
Old Feb 18, 2006 | 12:00 PM
nebechanezer's Avatar
nebechanezer
what were the york and sanden used on, or what years. what do i need for mounts on my 400
Old Feb 18, 2006 | 05:36 PM
fishmanndotcom
70's model just about anything. i actually just got a york bracket for a 400 but i believe i am going to be using it
ford vans had them as well as a lot of the old boat cars (large cadillacs)
-cutts-
