1997 Ranger Cooling problem
Old Feb 7, 2006 | 07:53 AM
asmech's Avatar
asmech
Hi guys,
Im having problems with the temp gauge on my Ranger. Once the tuck is warmed-up, If the rpm's go above 3000, the temp gauge will slowly drop to cold . It returns to normal when I shift and rpms return to 2000 or so. The truck did this once before under warrenty and Ford changed the T-stat and has worked great since. So far I changed the T-stat heater control valve (leaking) and temp sensor. When I had the lower hose off I could see a little of the water pump vanes and they looked ok. The truck never overheats too.
Hopefully someone has seen this before. Could radiator be partially clogged??????
Thanks in advance for the help!!!
Old Feb 7, 2006 | 10:01 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 7, 2006 | 06:37 PM
Ultramagdan's Avatar
Ultramagdan
I doubt the radiator is plugged. How cold is it where you're at?
tbear853
Nov 27, 2016 11:05 AM
Gatordog
Oct 21, 2015 10:06 AM
David7.3
30
Dec 24, 2014 09:18 AM
tjc transport
General Automotive Discussion
Nov 9, 2014 07:06 AM
fbh31118
67
Jun 19, 2014 01:24 PM
