moving the steering box forward
Old Feb 7, 2006 | 06:20 AM
wiseguy50's Avatar
wiseguy50
Question moving the steering box forward
i have a 56 100 with a 95 camaro column and a toyota box. i'm putting in buckets and the wheel is too close to my fat stomach. plus i'm a short guy 5-6
though i'm not Buddah yet. can i move the box forward on the frame (maybe a inch or so) without changing the pitch of the column. right now i have a 4'' drop?
or will the column rise as it goes forward. does anyone have other ideas? maybe a different column? open to all suggestions thank you
Old Feb 7, 2006 | 07:07 AM
4tl8ford's Avatar
4tl8ford
If you keep the column drop the same the steering wheel will drop.
More importent, MOVING THE STEERING BOX WILL CHANGE THE WHOLE GEOMETRY OF YOU STEERING.
Old Feb 7, 2006 | 08:02 AM
pootscratch89's Avatar
pootscratch89
That's what I'd worry about--changing the geometry of the set-up. I think maybe a shorter column might be in order...
Old Feb 7, 2006 | 08:07 AM
rogerf100's Avatar
rogerf100
A tilt column should help you. I put one in my '55 F100 and have lots of room now. I used a 30 inch Flaming River coulumn and a 3 inch drop. Pics are on my web page, see the link in my sig.
Old Feb 7, 2006 | 11:39 AM
wiseguy50's Avatar
wiseguy50
Question steering column
i have a 56-100 witn a 95 camaro column and toyota gear box. this was installed when i bought the truck. im changing bucket seats and the column is too close to my fat stomach plus im only 5-6. i'm not a buddah yet. anyways, can i move the gear box forward a inch or so on the frame rail and not raise the column in doing so? it looks like the gear adjustment may have a inch or so left. do i make sense? or i am open to any other advice you may have. the seat sits as far back as possible so im guessing i need to do some column work or replace? any ideas are appreciated. thank you
Old Feb 7, 2006 | 11:53 AM
wiseguy50's Avatar
wiseguy50
i do have tilt steering and i could always change the drop. it just seems as though i have no room for seat adjustments. right now the seat is all the way back and the column seems only a inch away. am i missing something?
Old Feb 7, 2006 | 01:20 PM
Okiedokie's Avatar
Okiedokie
I would bet the 30 inch column would be a better fit. How long is your 95 Camero column? What seats are installed?
Old Feb 7, 2006 | 02:21 PM
AXracer's Avatar
AXracer
Shorten the column, DON'T move the box, you're asking for trouble.
I had to shorten my Ididit column from 32 to 30" for the same reason.
If you are using a deep dish steering wheel, you may want it shorter yet.
