Sponsored by: Real Truck
Cold Air Intake
Old Feb 6, 2006 | 09:33 PM
jimvh2's Avatar
jimvh2
Cold Air Intake
I'm looking for a cold air intake for my 2005 SD 5.4L. The K & N and Airiad only go up to 2004. Any ideas??????
Old Feb 7, 2006 | 12:14 PM
Mark at DPPI's Avatar
Mark at DPPI
Take a look at the AFE systems, call us if you have any questions we'll be glad to help.
Mark @ DPPI
Old Feb 7, 2006 | 04:42 PM
lonestarpa's Avatar
lonestarpa
DryFlow is developing one in the near future. Enstead of an oil type filter it will be a washable and reusable dry one. Supposedly a better micron filtering and increased flow without the oil. This is supposedly good to prevent contaminating and coating you mass airflow sensor. I,ve been doing some research and am waiting for this to come out. Good luck!
Old Feb 7, 2006 | 05:41 PM
05F2504x4's Avatar
05F2504x4
Good luck with that. I've been looking for the same thing and can't find anyone that makes one for the 2005 5.4 F250.
Old Nov 2, 2007 | 08:01 AM
mxracer280's Avatar
mxracer280
hey i have the same truck. i got a k&n off of jegs....its the newest one.
good luck
Old Nov 2, 2007 | 08:10 AM
BADBLUEOVAL351's Avatar
BADBLUEOVAL351
Stay away from oil soaked filters unless you eventually want MAF sensor issues otherwise good luck
Old Nov 2, 2007 | 08:16 AM
WildWildWest's Avatar
WildWildWest
K&N builds them for the 2005 and up - they are called the 63 Series Aircharger kits. http://www.knfilters.com/search/product.aspx?Prod=63-2570
You shouldn't have MAF problems if you don't use excess oil on the filter.
Old Nov 2, 2007 | 08:34 AM
dkf's Avatar
dkf
Heres a link to a couple kits.
http://store.summitracing.com/egnsea...813803&NeXID=5
Saying that oiled filters will screw up you MAF is WRONG
Been using K&N filters for many years, not ONE MAF problem.
The MAF sensor should be cleaned on a regular basis regardless of filter used.
I clean my MAF twice a year with CRC MAF cleaner.
Don't over oil any filter, a light coat works best.
Old Nov 2, 2007 | 08:39 AM
BADBLUEOVAL351
http://store.summitracing.com/egnsearch.asp?N=700+4294925239+4294908331+42948464 76+4294907918+4294840115+115+4294813803&NeXID=5
You clean it twice a year how many others you think do that so on a basis that some over look the MAF, just maintain the filter and eventually without cleaning sensor due to excess oil over time it will mess the sensor up. may not break it but it will throw the sensors "sensing" capabilites off. you dig
Old Nov 2, 2007 | 08:54 AM
snelldawg's Avatar
snelldawg
Outlaw makes a cold air intake for the 05 5.4 too
Old Nov 2, 2007 | 11:08 AM
dkf's Avatar
dkf
The oil don't get on the MAF. I have never found any oil on my sensors. A lot of people may say it does, however thats mostly because of what they heard instead of actual experience.
You have to really cake on the oil before any will blow inside the housing, let alone work there way around the little wires in the MAF.
The MAF sensor is very important and should not be neglected like most do.
Old Nov 2, 2007 | 12:53 PM
akford351's Avatar
akford351
I have the Airaid Jr kit and its OK... noticed a little bit of a gain.
Old Nov 2, 2007 | 01:59 PM
redford's Avatar
redford
FTE Leadership Emeritus
Outlaw lists the INSM-0009 Intake System, Ford, Excursion/ F-250/ F-350, 5.4L, 1999 to 2005
Old Nov 2, 2007 | 06:07 PM
chuck06250's Avatar
chuck06250
Hey Mark at DPPI, I couldn't find it on your site. AFE's ite shows a Stage 1 kit though. How about an '06 F250 w/a 5.4?
Old Nov 7, 2007 | 07:46 AM
06SUPERDTY5.4's Avatar
06SUPERDTY5.4
i just recently installed the airaid on my 06 and thought that they were the same part number... maybe im wrong.. either way its a great aftermarket kit...
