Cruise Control Problem
Old Feb 6, 2006 | 03:13 PM
gomsu's Avatar
gomsu
I have a '91 Ranger STX 2WD, 3.0L, 5 speed (mazda tranny).
Going to work today and went to set the cruise and it wouldn't work. Never had a problem with it before. I'm going to check the fuse when I get a minute, but is there anything else regarding the cruise that I should check for if it's not the fuse?
Thanks.
Old Feb 6, 2006 | 03:29 PM
87 XLT's Avatar
87 XLT
This is probably wired the same as my 87, so see if the horn works.
If it does take a couple of minutes to pull the trouble codes. If you're lucky-like I was- you will get a vehicle speed sensor code.
30 bucks for the VSS at Napa & a couple minutes to replace it, & my CC was fixed.
Old Feb 6, 2006 | 07:40 PM
gomsu's Avatar
gomsu
I'll give it a try tomorrow. Thanks.
Old Feb 6, 2006 | 09:05 PM
Ken00's Avatar
Ken00
I should have some more information in the tech info thread at the top of this forum if it's not the fuse.
