Replaced O2 sensor - No change
Old Feb 5, 2006 | 04:03 PM
crawdad's Avatar
crawdad
A few days ago, I pulled the codes on my newly acquired truck (in sig). The codes I got were a 41, 53 & 96. At the time I had a pretty bad exhaust leak. I have since repaired the exhaust leak, and today, I put in a new O2 sensor. I cleared the codes by disconnecting the battery negative cable for a few seconds (is that the correct way?), and then hooked it back up and took the truck for a test run. When I got back, I pulled the codes again and I am still getting the same exact codes. I would have thought that by repairing the exhaust leak and replacing the O2 sensor that that would have cleared the 41 code. Your thoughts and suggestions on what else I should do would be much appreciated.
Old Feb 5, 2006 | 04:09 PM
quicklook2's Avatar
quicklook2
a few seconds is not long enough.
i do one hour but i think 5 minutes is enough.
Old Feb 5, 2006 | 04:30 PM
EPNCSU2006's Avatar
EPNCSU2006
You can clear the codes by pulling the jumper wire while the codes are being blinked out, without having to disconnect the battery.
Old Feb 5, 2006 | 04:36 PM
quicklook2's Avatar
quicklook2
thanks, epncsu, you are just a wealth of information.
crawdad's Avatar
crawdad
Ok, I was afraid I didn't leave the battery disconnected long enough. Appreciate the info.
Old Feb 5, 2006 | 05:11 PM
crawdad's Avatar
crawdad
Just went out and tried that and it worked like a charm, all cleared now. I, once again, took the truck for a test drive and checked it again when I came back. I'm still not showing any codes at all now. Is a 20 mile test run long enough for any codes to show up if they're going to?
Old Feb 5, 2006 | 05:15 PM
pfogle's Avatar
pfogle
You need about 30 minutes of driving time. This lets the computer relearn everything.
Old Feb 5, 2006 | 05:19 PM
crawdad's Avatar
crawdad
Ok, thanks.
MFogarty1996
Jun 25, 2011 01:38 AM
itsasix
17
Sep 1, 2010 09:33 AM
mediaman67
Nov 6, 2009 08:32 AM
nnewman
Oct 20, 2009 09:11 PM
