starting problem ,,, FUEL????
Old Jun 21, 2001 | 05:19 AM
dynamic's Avatar
dynamic
here is my problem ,,, I just finished putting my suspension back together after a head on collision ,, the truck has been sitting since last september,, i have started the truck a few times since then but it has been at least a few months since i started it,, well i started it ,, and it ran for like 3 or 4 minutes then sputtered and tried to stall as i gave it more gas it just stalled out ,, i tried to start it a few more times ,, and nothing ,, then i tried some starting fluid ,, and it runs till the fluid burns out ,, im guessing bad gas??? the tank is allmost full , so i dont want to have to drain it all out,, can i just add something to it to make it good gas. octane booster, dry gas,, anything???? and would this ,, could this be my problem? any ideas???
Old Jun 21, 2001 | 05:48 AM
jdbanks's Avatar
jdbanks
Could be bad fuel, but make sure you check the fuel pump, fuel filter and fuel line for leaks before you start doing anything. Check and make sure you're getting gas to the carb, if not then find where the gas is stopping at and fix whatever is wrong there. Could very well be the gas, but even on bad gas it seems like it would run, might run bad, but should run. Also make sure the carb bowl is full of fuel. Hope that helps and good luck.
*jdbanks*
Old Jun 21, 2001 | 06:50 AM
78f250's Avatar
78f250
Try the fuel filter first. Seems like every time I have a fuel type problem, this has something to do with it. Plus it's a cheap place to start.....
Old Jun 22, 2001 | 05:23 PM
f150sleeper's Avatar
f150sleeper
My guess would be the fuel pump. Ive had mine go out twice since ive owned it and it had the exact same symtoms as yours. Replaced the pump cranked it over long enough to get fuel in the bowls and and it fired right up.
1979 F150 CUSTOM 2WD 302 BORED .040 OVER EDELBROCK CAM, CARB AND INTAKE. C4 TRANNY AND A 9 INCH REAR END
Old Jun 24, 2001 | 05:30 PM
4ords's Avatar
4ords
Collision? runs for few moments with starting fluid? look for squashed or kinked fuel line. Most gas will be good enough for running 6- 12 months. Tom
Old Jun 24, 2001 | 05:36 PM
67beater's Avatar
67beater
I had a similar problem with mine. It turned out to be the fuel filter, even though it looked clean. Had some kind of clearish gunk in it. Replaced and the beast runs like a champ again.
Old Jun 27, 2001 | 05:33 AM
dynamic's Avatar
dynamic
well boys and girls, it was the GAS, after all, tosed the line coming from the inlet side of the pump into a gas can, cranked for a few minutes, and she started right up,
so im back to my Question???
can I do anything to the gas to make it good???
if not , what the hell am i susposed to do with 12 gallons of bad gas,, can ya say "Fire Pit"
Old Jun 27, 2001 | 07:40 AM
BlueRanger's Avatar
BlueRanger
