i recently lifted my truck with a 3 inch body lift and will be making long drives to college next fall so i was wondering if anybody knew of a good gas tank replacement option since theres so much more space under the bed now...i have a 16.5 gallon tank now and need more capacity
well theres so much more space under ther, plus i took out the spare tire so i think im gunna look for a bigger rectangular tank at a junkyard or something and make it work with sum flexsteel
also you may want to check out www.lmctruck.com... I too am looking for a larger tank than my stocker. i think its an 18 or a 19... they have a direct replacement 38 gallon tank, but again, you must lose the spare... it would be easier to just throw it in the bed anyways, esp if you have a toolbox on the bed, it can just slide right under.
cut the tank in half and make it 3 inches taller. After its all welded together get it lined on the inside and painted on the outside.
I have done it twice on F150 aft axle tanks and you will get about 28 gallons in the 19 gallon tank
