whats the next preventive
i've already did the basic used car stuff oil change (mobil 1),plugs(replaced#3 cop, flashed a code) fix a couple minor leaks (transfer case) and tires and aligment.
my question (s) is are what preventive maint. should i do to make sure i got long and trouble free life out of the truck.
there is now 3 out of 8 cop changed should i change out the rest?
coolant, should i do a flush and if so what the best to replacement?
auto trans. filter and flush ? with mobil 1 a/t?
transfer case fluid change with mobil 1 a/t?
front and rear diffs fluid change with mobil 1 75-90? what if any additives?
these are the major thing i think of, but since this is the newest truck i've ever owned, and havn't had a auto trans other the one in my 70cutlass, i not sure what works and whats best and what will last and how long.
i don't no the past maint so i assume the min. becouse the truck appear to be in good shape
so any thoughts on this and other possiblity would be every helpful
thanks
Transfer case is 2 quarts Mercon ATF. Transmission is Mercon for 4R100 or Mercon V (synthetic) for 4R70W, Check your transmission dipstick for correctness. And why not replace the pcv valve for good measure! I've used M/C 5W20 engine oil for 120,000 miles, and I still have no problems. No smoke, no noise. If you want to use synthetic, it's great stuff, just use the right weight.
