Bronco II Ford Bronco II
Rear window wiper
Old Feb 5, 2006 | 01:31 AM
MountainDreamer's Avatar
MountainDreamer
Rear window wiper
1986 Bronco II Eddie Bauer. I have been having a tought time finding a wiper blade for the rear window. It is not a standard style blade like the front wipers, even though that is what parts place usually list. To my knowledge it is the original assembly for the bronco. I was just wondering if anyone can point me in the right direction for finding the correct blade. Thanks.
Old Feb 6, 2006 | 08:18 PM
Ken00's Avatar
Ken00
My 1989 Ford book shows it as a normal looking wiper and lists the assembly as 17C403.
Old Feb 6, 2006 | 09:12 PM
Desert Dog's Avatar
Desert Dog
Wiper
You can buy a refill blade be carfull and remove the old one,reuse the metal strip insert a little pain in the you know what but it should work.
Old Feb 6, 2006 | 11:16 PM
MountainDreamer
Where can you find the refill? thanks
Old Feb 7, 2006 | 07:40 AM
OSin86's Avatar
OSin86
It's a common assembly. Go to advance auto, they have about 3 units to choose from that will snap right into place.
Old Feb 12, 2006 | 09:33 PM
MountainDreamer
Actually I took mine to advance auto parts, but they didnt have the blade replacement. He had seen some camber systems as he called it, but said didnt even know if they could order the part. The blade assembly is only about a quater inch thick with a metal jacket that retains a flat portion of rubber. then it is all held together and to the arm by one pin. any help for this possible oddity would be great. thanks everyone for the effort so far.
