4.6 Adequate power?
Old Feb 9, 2006 | 10:03 PM
  #46
Onespeed24's Avatar
Onespeed24
I think there is a "replacement for displacement", it's called technology...
Everyone cryed when Ford replaced the potent 302/5.0l in the Mustang with the modular V-8 281/4.6l, until they realized that it made more power and got better gas mileage. I know, they are different engine types and the 4.6 and 5.4 in question here are more similar, but the concept remains true. Hell, look at these little 2.0l 4 cylinder cars that are pushing 300whp, they will argue the displacement theory all day long. I know of a 2.0l Focus running 260whp on all motor, my 1991 GT with 150% more displacement only made that much power with lots of bolt-ons. My father-in-laws '98 Cobra 4.6l mkes about 380Hp, way more than a similarly equipped 5.0l.
Not arguing that the 5.4 makes a lot more power than the 4.6, just pointing out the fact that once the load is rolling, usuable HP is probably pretty close between the two.
Someone mentioned that the 5.4 gets a better tranny... maybe that's a reason why the truck seems to pull better on hills. Gearing can have as much to do with how the power gets to the ground as displacement.
Old Feb 10, 2006 | 09:06 AM
  #47
osbornk's Avatar
osbornk
You can make a large amount of raw horsepower with technology but it's generally at much higher rpms than you use towing. But you have to remember that the 5.4 has both technology and cubic inches advantages over the 4.6. It has both 3 valves per cylinder as well as variable valve timing which helps a lot at towing. The heavier duty transmission and rear end doesn't help the towing ability-just the durability. With the same gearing, give me the 5.4 in my tow vehicle and I will use less fuel towing than with the 4.6.
I like small engines with high horsepower. I had one of the very early Shelby Chargers with the 2.2 Turbo engine. It was a pig until 3,000 RPMS and then it would snap your neck and create torque steer that wouldn't quit.
Old Feb 10, 2006 | 09:14 AM
  #48
ggarrahan's Avatar
ggarrahan
Torque at relatively low engine speeds gets the load moving. You could stick a 260 HP, 2 liter motor in a truck, and it would be useless. Technology is fine, but low RPM torque in a gasoline motor is more a function of displacement than anything else.
Old Feb 10, 2006 | 09:43 AM
  #49
Birdhunter1's Avatar
Birdhunter1
I can argue that, the 300 I-6 had more low ened torque that any of these current V8's which have much more displacement.
Long stroke provides your low end torque, not displacement.
Old Feb 10, 2006 | 09:29 PM
  #50
osbornk's Avatar
osbornk
Your 300 is a 4.9 which is a larger engine than the 4.6 Ford, 4.7 Toyota, 4.8 Chevrolet and the 4.7 Dodge. They are all V8s. There is a only a little over 33 cubic inches between your 300 and the 5.4 Ford and 27 between the 5.3 Chevy.
Old Feb 11, 2006 | 11:19 AM
  #51
99F150's Avatar
99F150
Originally Posted by Rickenbacker620
Howdy,
Called my local Ford dealer and asked about an F-150 XL REG. cab w/ 5.4, auto, A/C, and cruise and he told me that he wanted to help but, his dealership didn't ORDER reg. cab 2WD 5.4 F-150's!
He said that they COULD, but it was an unpopular cinfiguration. To be fair, the man was polite and willing to try when I was ready (it'll be a few more weeks 'til I actually buy). He told me that reg. cab was pretty much just for the V-6! No thanks.
Surely the reg. cab can be found w/ the 5.4..I am interested in Ford, despite the seeming uphill battle I'm fighting in finding one configured my way.
Rickenbacker620
PS: I'll consider a 4.6, too.
V6 no way?
I had a 99 F150 Supercab with the V6 5speed and 3.08 rear gear. PLenty of power and good MPG to boot. I towed my Star craft Tent camper that weighs 2750# in tow condition all over the country with it.
Brian the mod in the V6 forum has a reg cab 2005 V6 with the auto and is very pleased with it.
Don't count out the V6 till you drive one espescially if you know how to shift!
Old Feb 11, 2006 | 01:25 PM
  #52
Birdhunter1
I'm not saying the 4.9 isn't bigger or smaller I am saying that the low end of the 300 is much better for practical towing purposes.
If I was around town and stop and go I'd rather have my old 300 I-6 over a 5.4 V8. Displacement be darned the low end of a long stroke engine is much better than a shorter stroked engine.
Old Feb 11, 2006 | 08:41 PM
  #53
osbornk's Avatar
osbornk
Towed heavy with both and there is no comparison. The 5.4 is far far superior. However, I don't tow in town with stop and go driving. You can do that with anything with a trailer hitch.
Old Feb 11, 2006 | 09:45 PM
  #54
Mr. PC's Avatar
Mr. PC
Howdy,
Hmmmm-- I'm currently enjoying my regular cab 5.4 xlt with the 8' box. I bought it mid-December. I guess the hitch is that I ordered it. I had a very helpful and reasonable dealer (Jeff at Van Bortel).
PC
matt167
2004 - 2008 F150
Oct 15, 2014 04:17 PM
SuperDutyScaler
1997 - 2003 F150
Jul 31, 2014 07:53 PM
mudduc971
New Member Introductions
Mar 13, 2014 01:57 PM
fordman19762003
2004 - 2008 F150
Mar 29, 2012 07:54 PM
CJK440
1997 - 2003 F150
26
Nov 12, 2007 05:41 PM
