Backpressure?
Old Feb 4, 2006 | 01:29 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Backpressure?
Would I have enough backpressure if I cut the stock muffler off of my 4.6L? The stock cats and everything would still be on there. I just did this to a friends truck, and it sounds awesome!
Old Feb 4, 2006 | 04:08 PM
Octane's Avatar
Octane
I think you would lose some low rpm power. When I first bought my '99 F-150, thats now the exhaust was. It was basically dual straight pipes after the cat.
I put a Flowmaster 50 Series on it and it you can feel the gain in lowend power, not the mention the fact that it sounds good, not just loud.
Old Feb 4, 2006 | 04:13 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Thanks for the reply. My friend's Dodge had a Flowmaster (2.5" SI/DO) on it...not sure of what series it was (Im thinking 50 series), and he said I could have it. I just wanted to run around with no muffler for a while to see what it was like. If I dont like it, I can put his old Flowmaster on...
Old Feb 4, 2006 | 07:15 PM
Torque1st's Avatar
Torque1st
Posting Legend
Moved to proper forum.
Old Feb 5, 2006 | 10:28 AM
jjg052590's Avatar
jjg052590
Yeah you will lose some low end torque.. I simply got a new si/do muffler and had to change the inlet from 2.5" to 3" and lost some..
Old Feb 5, 2006 | 11:41 AM
351M's Avatar
351M
It will be just fine without the muffler, the cats are more then enough to keep you from losing low end. Better yet, get rid of the cats, and get a good free flowing muffler, long magnaflow or somthing like that. A 2.5" system on that should be fairly decent. As far as sound without the muffler, seems alot like it, the cats are supposed to give it a fairly decent tone.
Old Feb 5, 2006 | 01:47 PM
kens64's Avatar
kens64
Yup, the engine will blow up if you take that muffler off.
Seriously, read up on backpressure vs velocity and flow and you will find your answer. To anyone that thinks they lost torque from just changing/removing the muffler and leaving everything else stock, think again. But then if backpressure is good, then a banana in the tailpipe must be great, right?
The butt dyno is NEVER accurate.
Old Feb 5, 2006 | 05:05 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Heh...I just need to talk my dad into letting me do it. For some reason, he was complaining the other day after cutting my friend's exhaust off...saying that it was $1,000 worth of pipes It was just a cat-back system with one Flowmaster 50-series. He doesn't want me to do it, because he thinks that's how much it will cost to fix mine. The stock exhaust exits in front of the passenger rear tire. After the muffler, its only a 2.5 foot section of pipe
To put his old Flowmaster on, would only take an adapter, one clamp and a hanger of some sort. $10 at Advance.
Old Feb 7, 2006 | 09:41 AM
351M's Avatar
351M
Do like I used to, with all my vehicles (and my dads). Wait till he isn't home for an entire day or go elsewhere and do the job.
Old Feb 8, 2006 | 07:11 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
I was going to say that if you REALLY want power, you need to stuff a potato in the exhaust pipe. Just make sure that it's completely sealed and you'll have so much backpressure that you might start popping wheelies.
However, I see that kens64 beat me to it.
Cody
Old Feb 8, 2006 | 12:03 PM
preppypyro's Avatar
preppypyro
Just carry a sack of potatoes around and when you want to race, stuff one in and youll never lose
Old Feb 10, 2006 | 10:07 PM
351M's Avatar
351M
Thought I would add this to make a point. Today I was looking at a motorhome, Vortec 8100 powered Triple E Commander to be exact. I though I would have a look at the exhaust system as it has a 4"-4.5" tail pipe. It had dual 3" or 3.5" pipes into dual cats and mufflers that Y into the 4" tail pipe at the rear diff. What does a Chev pickup run on that engine? I was actually amazed at the difference in size of the systems. BTW, the low tone from that system actually shook the wash bay at work when we backed it out. I suppose though, you can't cheap out on a $250,000 dollar motorhome right?
Old Feb 11, 2006 | 08:07 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
The Chevy trucks with the 8.1L use a short (4" length) amount of pipe off of the exhaust manifolds that is 2.5". After that, the pipe off of each manifold becomes 3". The system remains 3" through a catalytic convertor (one per pipe) and 3" dual into the muffler. From there, it is a DUAL OUTLET muffler (3" each) and immediately into a "y" to ONE 3.5" tailpipe.
Cody
Old Feb 11, 2006 | 09:29 AM
351M's Avatar
351M
So similar then. Its a heck of a system though. Don't know why more companies can't do somthing thing like that. Getting better flow is then just as simple as getting rid of the single tail pipe, and maybe better mufflers.
Old Feb 11, 2006 | 01:19 PM
hunter1988's Avatar
hunter1988
Sounds like my dad.. I am just gonnna wait for the major repairs and accessories when I go to college this fall.. lol...
