Backpressure?
Old Feb 11, 2006 | 05:54 PM
looneylariat's Avatar
looneylariat
Man Cleatus that's a nice looking truck! Those 49's look good under there!
Old Feb 11, 2006 | 06:10 PM
F6Guy's Avatar
F6Guy
kens64 is correct. the goal is zero backpressure. to put it simply Backpressure bad, High velocity good. The balance is in the pipe diameter. If you slow down the velocity you will loose the scavaging effect, speed it up and you increase it. Thats why most people say they loose power by putting straight pipes or bigger dia. pipes, the exaust gas is slowing down as it leaves the motor.
Old Feb 11, 2006 | 07:57 PM
hunter1988's Avatar
hunter1988
so what would you do forbetter gas mileage, I am confused (but thats easily done)...
Old Feb 11, 2006 | 09:08 PM
kens64's Avatar
kens64
Just do what 351M said in his first post. Free up the exhaust system, retune for the better breathing, and you should get better mileage.
Old Feb 11, 2006 | 11:45 PM
F6Guy's Avatar
F6Guy
on a 4.6 engine if going without a muffler I would go no larger than duel 2.250" pipes or a single 3.5" pipe. And run it at least past the cab. You will probly want a muffler on it after a week anyway.
Old Feb 12, 2006 | 10:43 AM
351M's Avatar
351M
Yeah, dual 2.25" is fine but no more then a single 3", there isn't a point in going much larger.
23larry24
15
Nov 29, 2012 10:30 AM
turdbird
18
Apr 1, 2006 08:29 PM
prevailracing
Nov 23, 2004 06:13 AM
BigDawg54
Mar 4, 2004 12:33 PM
Josh00
22
Aug 16, 2000 05:03 PM
