Leveling kit install questions
Old Feb 4, 2006 | 12:23 PM
JUMBO_UTE's Avatar
JUMBO_UTE
Question Leveling kit install questions
I am looking to install a leveling kit in my 00 X. The kit instructions say to unbolt the shock absorber, disconnect the stabilizer bar link, and then force the axle down, allowing the spring to come out. Isn't the spring under tension before you force the axle down? I don't want to move the axle if the spring is under tension? Anyone do this before? Thanks.
Old Feb 4, 2006 | 08:28 PM
TN_Jeeper's Avatar
TN_Jeeper
The spring is under tension when you raise the axle up. Once you unhook everything the axle will droop and the spring should pull out, top first.
Old Feb 5, 2006 | 02:11 PM
JUMBO_UTE's Avatar
JUMBO_UTE
Ok, now I guess I'll have to use my jack to push the axle back into position. Thanks.
