360 -390 rebuild
Old Jun 30, 2001 | 04:24 AM
wildebeast's Avatar
wildebeast
360 -390 rebuild
on someones post i read about putting a 428 crank in a 360-390 block would like more info on that if who ever potsed it would be so kind my 75 that i run ive run a 360 with a rv cam for a 120000 now valves are going as the exhaust valves are a litte small but i dont like the 351-400 engines and big blocks are to easy to over rev when ##### deep in mud so id like to stick with a 360 - 390 but more power and torqe would be nice can anyone help?
75 highboy wildebeast stomps all general mexican motor
Old Jun 30, 2001 | 07:01 AM
StockMan's Avatar
StockMan
360 -390 rebuild
[FONT COLOR="#0000ff" SIZE="3" FACE="Veranda"]
Use the search feature. It's a great tool which is often overlooked. Thanks.
[/FONT]
[LINK:www.hometown.aol.com/tbeeee|http://members.aol.com/tbeeee/page/registrysig.gif]
Old Jun 30, 2001 | 08:11 AM
1975F250's Avatar
1975F250
360 -390 rebuild
428 Crank will work in the 352, 360, 390 blocks. even a 406 if you found one, the 406 crank is the same, just less piston. the 390 must be bored .080 over standard for the 428 pistom. I recommend Ross racing pistons. They have a 9.0 to 1 light weight piston that gives good revs and no worries about fuel quality.
The stock rods with arp bolts should give you 5500 limit without worries of flying apart.
Make sure you have the block checked closely for cyl. wall thickness if it is an early 428 block or a late 390 block.
A 391 truck block would be the stronger block to have though.
Hope this helps.
Old Jun 30, 2001 | 09:25 AM
dinosaurfan's Avatar
dinosaurfan
360 -390 rebuild
Wild, the 410/428 cranks are available but usually exspensive. Look at swap meets, on E-bay and ask you local machine shops. The casting numbers are 1U, 1UA and 1UB. I would expect one to cost you 300$ or more. Good luck with the hunt! DF
Old Jun 30, 2001 | 05:37 PM
PetesPonies's Avatar
PetesPonies
360 -390 rebuild
Lets straighten out a few things. First, yes a 428 crank can be installed. theya re expensive so plan to pay a few bucks. You will then need 390 connecting rods. This along with the correct set of pistons ( bore tyhe block to 390 specs) will yield
410 CI. I would not suggest trying to bore farther than that. This is an engine ( 410 ) that Mercury offered and you can get pistons for thay engine. A 406 crank is the same as a 390 crank. Disregard that previous info, not that you would find any 406 parts anyway; very rare. Basically a 406 is a 428 bore with a 390 crank. You should go with a 390 bore, shorter 390/428 rods and either a 390 crank ( cheap) or a 428 crank ( $$$$ ) and the appropriate piston.
Pete's Ponies
Mustang RUSToration & Performance
Old Jun 30, 2001 | 06:10 PM
dynamic's Avatar
dynamic
360 -390 rebuild
greentruck72
27
Oct 4, 2016 03:47 PM
supercabfreak
Jul 20, 2010 10:15 AM
71LTD390
Apr 17, 2004 10:33 AM
67 428 Fairlane Ranchero
Jan 30, 2003 08:12 PM
72 F-100 Ranger XLT
Jan 26, 2003 11:18 AM
