Side Mirror Bulb Replacement 1998 expy
Old Feb 4, 2006 | 12:29 AM
sbajr75's Avatar
sbajr75
Can someone please tell me how to get the side mirror housing off to replace the side mirror bulb in a 1998 EXPY.
Thank You
Old Feb 4, 2006 | 07:26 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 4, 2006 | 09:37 AM
01silvergt's Avatar
01silvergt
Thank You
I assume you are talking about the turn signal in the mirror itself? If so, there is not a replacement bulb for it. They are LED, you will have to replace the mirror. They were made by KW Muth and can be found at www.kwmuth.com .
Old Feb 6, 2006 | 06:23 AM
scholzee's Avatar
scholzee
My 2001 has the light on the oter edge of the mirror housing. Tilt the mirror all the way down and look in between the back of mirror glass and inside the housing, there are 2 silver clips at the top. with a small thin screw driver lift the silver tabs and the colored part of the mirror housing comes off. You then have access to the bulb. If you do a search on this site someone has a better discrition that I saw once. I replaced both mine in less than 15 minutes.
Old Feb 6, 2006 | 07:27 AM
01silvergt's Avatar
01silvergt
98 and 99 Expys had the signals in the mirror, they were LED arrows behind the glass, much like Chevy uses on their trucks now.
Old Nov 13, 2008 | 08:10 AM
Brandon_01's Avatar
Brandon_01
My 2001 has the light on the oter edge of the mirror housing. Tilt the mirror all the way down and look in between the back of mirror glass and inside the housing, there are 2 silver clips at the top. with a small thin screw driver lift the silver tabs and the colored part of the mirror housing comes off. You then have access to the bulb. If you do a search on this site someone has a better description that I saw once. I replaced both mine in less than 15 minutes.
Hey gang! I am about to purchase an 01 Expy ED. Great truck. A lady owned it and she took great care of it. I'm picking it up for $5,500, thanks to me knowing the sales manager at the dealership.
I have noticed that neither of the turn signals on the outer rim of the mirrors are working. Could someone help me find on this site the "better description" for how to get to the bulb so I can replace it? Any help would be greatly appreciated.
Thanks.
****Edit: Never mind, I found it! https://www.ford-trucks.com/forums/2...ml#post6762362
in heat
Jun 10, 2012 11:00 PM
brow603
1997 - 2003 F150
Sep 1, 2007 04:14 PM
t_lcohen
Mar 6, 2007 04:49 PM
jcb67
19
Apr 3, 2003 09:38 AM
