timing advance
https://www.ford-trucks.com/dcforum/DCForumID7/242.html
Looking at this it seems that total advance should be around 39 degrees. Yes the advance should increase even with the vacuum line unhooked and plugged. A distributor has 2 means to advance, the vacuum advance of which you are aware, and a centrifical advance. This consists of weights that spin outwards as the engine speeds up and thus produce a twisting force that advances the distributor. As for information on the vacuum advance, I think you already have several responses to your thread on the FE forum.
Bob
I understand the vac adv should be timmed, that is it should be 0 at idle and kick in briefly when the carb is opened then go back to 0.
One of the easy ways to set the timming, is to advance until 2 deg at a time until you have pinging under load on a warm day, then back off 2 deg.
The BEST way to time, it to pay a pro $75 to recurve the dist specfic to your setup.
