95 Explorer Ignition
Old 02-03-2006, 11:29 PM
akybuckeye's Avatar
akybuckeye
akybuckeye is offline
Can anyone please tell me how to change the ignition switch in a 95 explorer? My daughter lost her keys and now we cant move her vehicle. I bought a new switch but I have no clue how to do it since it is in the lock position. How hard is it to do? Any help would be appreciated
Old 02-04-2006, 01:26 AM
mountaineer man's Avatar
mountaineer man
mountaineer man is offline
just take the vin info to ford dealer and they should be able to make a new key
if not you do not to need the switch it is not part of the key i had to replace the tumbler after a the car was broken into and stolen
Old 02-04-2006, 09:26 AM
akybuckeye's Avatar
akybuckeye
95 Explorer Ignition Replacement
We did call the Ford dealers and they can only do 96 and newer. Needless to say this one is a 95...Someone told me that the old one has to be drilled out...then again I heard from a Ford parts man that it can be popped out...HELP!!!!!!!!!!!!
Old 02-04-2006, 03:52 PM
mountaineer man
here is what i did
take the column apart and you can remove the screws that hold the ingnition assembly on the column and replace the whole unit with a new one or one from a wrecking yard just make sure you get the key too I would get the door locks and trunk or hatch lock too that`s what i did
fordman19762003
Electrical Systems/Wiring
01-17-2016 06:03 AM
rallynutdon
06-29-2006 12:03 PM
RedBoat
06-27-2006 04:18 PM
JCardoza81
05-17-2004 09:17 AM
mazdajunk
02-12-2004 10:09 AM
Quick Reply: 95 Explorer Ignition
