starting question
Old Jul 3, 2001 | 10:42 PM
madcow's Avatar
madcow
starting question
Hi everyone. I have a 71 250 that i have a question about.
On a hot day when my truck is parked for hours, is my truck supposed to start without the choke engaged?
My truck will start then die right away but if i hit the choke then it will stay lit.
thanx for any replies
Old Jul 3, 2001 | 11:17 PM
otto's Avatar
otto
starting question
then I would recomend choking it whenever starting it "cold" even if the ambient temp is 90 degrees
Old Jul 3, 2001 | 11:21 PM
minus's Avatar
minus
starting question
It is my understanding that any engine needs a rich mixture to start and to warm up. A richer mix helps start easier and run while the engine is cold. Remember it could be 100 degrees out and you can still have a cold engine. The choke helps create a temp rich condition by regulating airflow. Hot and cold has nothing to do with the air temp its mostly coolant.
mike 'minus' easter
53 f-100 , 1970 429
3" exh with flows
4speed and a 9"
"how fast does it go" 'lets just say it moves'
Old Jul 3, 2001 | 11:27 PM
otto's Avatar
otto
starting question
mike "minus" easter is right
Old Jul 4, 2001 | 02:15 AM
Ranger7104's Avatar
Ranger7104
starting question
Heesman
Sep 5, 2014 03:00 PM
rustyleerusk
18
Jun 7, 2014 11:04 PM
okie72
Jan 29, 2014 09:32 PM
HolyHandGrenade
Nov 6, 2012 01:32 PM
86rustbucket
Mar 13, 2008 06:41 PM
