compression checked my engine...
Old Feb 3, 2006 | 03:26 PM
nebechanezer's Avatar
nebechanezer
stock 400 in '77 f-250, came up w/ 105-115 lbs on 7 cylinders, 50lbs on 1. going to check the low one w/ a leak-down tester. my question is are the other #s low, should they be higher than 110-ish? i have no idea no the mileage or history of this engine, i dont think its the original. i am planning on eventually rebuilding it either way , was just curious what kind of #'s a fresh engine would have to gauge the condition of mine
Old Feb 3, 2006 | 04:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
Check out post #8 in this thread:
https://www.ford-trucks.com/forums/s...d.php?t=455553
Old Feb 3, 2006 | 07:50 PM
danlee's Avatar
danlee
Atmospheric Pressure is approximately 14.7 PSI at Sea Level. The intake valve on a '77 400 motor closes at 53 degrees ABDC. The Dynamic Compression Ratio based on that IVC is approximately 7.16:1. 14.7 x 7.16 = 105.25 PSI compression.
I would say that your readings on 7 cilinders are OK. The best way to tell is by the uniformity of the readings. If they measured 110 PSI and varied by +/- 5 pounds, that is a good result.
skinsey
13
Sep 26, 2005 10:22 AM
armstpe
26
Apr 29, 2005 12:58 PM
Mmatto99
Feb 12, 2005 10:29 PM
fordzrule
Mar 5, 2002 10:09 AM
