shift collar needs help!
Old Feb 3, 2006 | 12:08 PM
SuperFord's Avatar
SuperFord
I had a broken shift collar. I got a new one and replaced it but now the collar is loose. It does not clamp down on the shaft. My gear locations are all messed up now. I can push on the collar and slide it down further on the shaft. I made sure the snap ring was seated in the groove, but what else holds it down? I need help!
Old Feb 3, 2006 | 12:51 PM
Mil1ion's Avatar
Mil1ion
3 hold down clamps with allen head screws that are removed from the back the collar.
There is also a small bolt that holds the column together.
