Offroad & 4x4
Brakes question
Old Feb 2, 2006 | 08:25 PM
OffRoadF-150's Avatar
OffRoadF-150
Brakes question
I have a 96 f-150 and i have just finshed puttin a new front end under the truck from a 1978 f-150 for the SAS. I bought new 1978 calipers and new extended 1996 brake lines. Ive bled the brakes and there is resistance in the pedal. However, when i turn the truck on, the pedal goes straight to the floor and i have no brakin power. The reservoir is full and there is not leaks in the new lines. Does anybody know whats wrong with my brakes and how to fix em. Ive bled them and it seems to work till the truck is turned on. The ABS light is on too. I know this question might not be best in this forum but i know yall know alot about both of these trucks. Any suggestions or help would be very helpful.
Thanks,
Will
Old Feb 3, 2006 | 09:44 AM
ramboss429's Avatar
ramboss429
Did you bleed the master cylinder?
Old Feb 3, 2006 | 02:12 PM
76fordtruck's Avatar
76fordtruck
one word of advice... dont push so hard on the pedal that you shoot the bench bleeding plugs out and the fluid all over your buddy ... i know this from experience.
Old Feb 3, 2006 | 02:25 PM
s8whiskey's Avatar
s8whiskey
Make sure you bleed the master cylinder and that you bled the brakes from the rear left around and ending on the front left.
Old Feb 4, 2006 | 12:00 AM
chrono4's Avatar
chrono4
if you pump them, does it build up?
Old Feb 4, 2006 | 08:54 AM
teds74ford's Avatar
teds74ford
I would think it is a master cylinder problem too. I am not really an F150 guy, though, so for those of you that are, is there a big difference in caliper volume from the 78 to the 96? Maybe it just doesn't have enough to supply the older calipers?
Old Feb 4, 2006 | 10:45 AM
chrono4's Avatar
chrono4
ted, that was kinda what i was thinking.
Old Feb 4, 2006 | 11:40 AM
tjc transport's Avatar
tjc transport
i ain't rite
how are you bleeding the brakes?? are you using a pressure pot, gravity bleed, or are you pumping the pedal with the engine off??
Old Feb 5, 2006 | 09:06 AM
OffRoadF-150
im pumping the pedal with the engine off, i did every brake in the specified order and still nothin. I was told i may need to get it power bled at a shop
Old Feb 5, 2006 | 01:11 PM
s8whiskey's Avatar
s8whiskey
power bled is nothing more then a power input with no air. Its nice just cost money for a simple job.
