Sponsored by: Kumho
Brakes question
Old Feb 2, 2006 | 05:52 PM
OffRoadF-150's Avatar
OffRoadF-150
Brakes question
I have a 96 f-150 and i have just finshed puttin a new front end under the truck from a 1978 f-150. I bought new 1978 calipers and new extended 1996 brake lines. Ive bled the brakes and there is resistance in the pedal. However, when i turn the truck on, the pedal goes straight to the floor and i have no brakin power. The reservoir is full and there is not leaks in the new lines. Does anybody know whats wrong with my brakes and how to fix em. Ive bled them and it seems to work till the truck is turned on. The ABS light is on too. Any suggestions or help would be very helpful.
Thanks,
Will
Old Feb 7, 2006 | 02:22 PM
1975Ford's Avatar
1975Ford
Verify the bleeder valves are facing truely up on the brake calipers,
here a site that cover brake test well, refer to the low pedal or no pedal test. http://www.classicperform.com/TechBo...oubleshoot.htm
