windshield wiper problem
Old Feb 2, 2006 | 03:39 PM
two_as_one2002's Avatar
two_as_one2002
Question windshield wiper problem
I have a 1996 F250 Diesel and the wipers don't work but the washer button does...Does anyone know what could be wrong with it and if so where do I start?
Old Feb 2, 2006 | 04:19 PM
DaveBowman's Avatar
DaveBowman
The MultiFunction switch is a very common problem on your truck.
Old Feb 2, 2006 | 06:24 PM
two_as_one2002
do I need to replace the whole switch?
Old Feb 2, 2006 | 07:02 PM
mdjohnson's Avatar
mdjohnson
How much is a new multi function switch?
Old Feb 2, 2006 | 09:50 PM
two_as_one2002
It's $60.00 at advance auto
Old Feb 3, 2006 | 10:20 AM
mdjohnson's Avatar
mdjohnson
I'll have to get a new one. My wipers only work on high.
Thanks.
Old Feb 4, 2006 | 09:02 AM
whiteyfordzx5's Avatar
whiteyfordzx5
Thanks.
if they only work on high i'd almost guarantee you that your problem isn't the switch but the intermittent module that plugs in BEHIND the switch. on vehicles equipped with the intermittent wiper option, there's a module that plugs inline to the wiper switch. crawl under the dash and follow the harness backward from the switch. you'll find it. unplug it at either end and then open up the lil black box. check all the components on the circuit board for loose or broken solder joints. the most common seems to be the giant heatsink (that's what it was on mine). re-solder any loose components and you should be all set.
Mike
Old Feb 4, 2006 | 09:09 AM
preppypyro's Avatar
preppypyro
My wipers in my 89 started screwing up too. Only they go very very slowly, I just assumed it was the wiper motor, I will have to check the intermittent module.
Old Feb 4, 2006 | 11:07 AM
DaveBowman's Avatar
DaveBowman
I just said teh MultiFunction switch is a very common problem, not what your problem is. If the wipers only work on certain speeds, or if they start and stop every time you bump the switch or turn the blinker on and off then its a bad MF switch.
Old Feb 4, 2006 | 11:08 AM
DaveBowman's Avatar
DaveBowman
If they run slowly its a bad motor.
Old Feb 4, 2006 | 12:40 PM
preppypyro's Avatar
preppypyro
Thanks, will check that for sure
Old Feb 4, 2006 | 12:42 PM
mdjohnson's Avatar
mdjohnson
Does anyone have a schematic of the mulit function switch and the intermittent module that plugs in behind the switch?
Thanks.
Old Feb 4, 2006 | 05:42 PM
quicklook2's Avatar
quicklook2
you can clean the switch and see if that helps.
here is how to do it.
http://www.tauruscarclub.com/wiki/in...witch_Cleaning
eraser5
Nov 17, 2010 05:34 PM
ZukBox II
Oct 11, 2010 03:01 AM
dcicc50
Feb 6, 2009 04:34 PM
RabidJade
Paint & Bodywork
Mar 30, 2007 08:59 PM
