need help, smoking 390.....
Old Feb 2, 2006 | 11:59 AM
66flareside's Avatar
66flareside
I have a 1972 f-250 camper special with a 390. The guy i bought it off of said it needed different heads because the current heads (c8aeh) did'nt have hardened valve seats, and that's why it smokes. That's all fine, but upon reading some thread here, I wondered if we was right. The motor runs great, and dosen't smoke at all until it's hot. Does that fit the description of soft valve seats?
Old Feb 2, 2006 | 12:42 PM
bertha66's Avatar
bertha66
The c8, I think would make those heads from 1968, and they would not have the hard seats. But you smoking sounds more along the lines of worn valve guides and or seals. If the engine is running great, I don't think your valve seats are worn though. I have been running a 67 390 with out the harden seats with no problems, I got the engine in 1971 with 40k on it and I put rings and bearings in it in 1981 and put it in my 66 F-100 4x4 and it's been running great all along.
Old Feb 2, 2006 | 12:45 PM
66flareside
should i use a lead substitute or just keep running regular unleaded?
Old Feb 2, 2006 | 01:38 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
If it were rings, it would smoke on startup and clear up as it warms up.
If it were the valve guides, it would do it on startup and clear up pretty quick, usually.
I wonder ...
Next time it's smoking, the more the better, pull the PCV valve out of the valve cover, and see if you see oil pooling in the head.
Sounds like the heads are filling with oil and running down the valve guides. Worn rocker arms and shafts will cause this...
Old Feb 2, 2006 | 01:55 PM
66flareside
o.k i'll try that and get back later......
Old Feb 2, 2006 | 01:57 PM
66flareside
oh, and I am running 10w-30 (i live in the mountains of colorado). should I run a thicker oil?
Old Feb 3, 2006 | 12:10 AM
Hypoid's Avatar
Hypoid
Stick with the lighter oil for the winter. Heavier oil takes longer to distribute through the motor, which puts more wear on all those dry bearings.
Trivia: One dry start wears bearings the equivilant of 500 highway miles.
I agree with Art; if it works, don't fix it quite yet. The valve stems came with rubber seals on the top. The rubber hardens, breaks up and clogs the drainback holes at the corners of the head. The oil pools till it's level reaches the intake, then drains down the valley under the intake. This puts the valve stems under oil.
You may have to pull the valve covers to check the lower drains. I seem to remember my covers having baffles under the openings.
Old Feb 3, 2006 | 06:02 AM
scamardo's Avatar
scamardo
Along with all mentioned above, I recently went through worn valves due to non-hardened seats. Compression test found low on 3 cylinders but I had NO smoke. I did have a miss at idle and cruise that was hard to diagnose. 66 390 heads.
A compression test will let you know if the seats are heading south.
Old Feb 10, 2006 | 01:20 PM
66flareside
ok i'll try a compression test, that's a good idea........
