Gauges For Pillar Pod
Old Feb 2, 2006 | 01:05 AM
dfwf250's Avatar
dfwf250
Hello,
Im new to this forum and I guess I'am late to this party....because I've had my f250 since 99....so I just want to do some things to it and see if I can get some direction of what I need to do.....I want to put a pillar pod with maybe three gauges, but not sure where to get them and which ones I need....I would like to get ford racing gauges...but if there is something better then good...so help please thanks
Old Feb 2, 2006 | 01:22 AM
dsldandually's Avatar
dsldandually
I just got some off Evil bay for a good price they went up alittle http://cgi.ebay.com/ebaymotors/Autom...2951QQtcZphoto
just a thought I like the Autometers they make real quality stuff, there are other good gauges out there too. that link is for a complete kit with pod, guages (pyro,boost) and everything needed to hook them up, just paint the pillar and hook everything up
Old Feb 2, 2006 | 01:35 AM
dfwf250's Avatar
dfwf250
did you install them yourself....and how difficult was it.....I just went to the link and those look good...wish they had them w/ white faces
Old Feb 2, 2006 | 01:59 AM
dsldandually
actually the ones in the picture are Banks gauges if you go to summit and search the part# it will show you the gauges. The install was pretty easy I put the pyro probe pre-turbo so I had to drill out the exhaust manifold which was probably the hardest part just grease up acouple drill bits small to desired size and drill straight up the grease will trap 99% of the metal shavings I took the shop vac and sucked the hole before installing the probe just for piece of mind.
if you search the sellers other auctions he has different gauges all with the same picture you just have to do alittle research of the part#s to see which gauges hes selling in which auction
you can also try some of the sponsors or egauges.com has all kinds of stuff
Old Feb 2, 2006 | 04:29 AM
JOE-M's Avatar
JOE-M
I bought them from one of our sponsors. Here:http://campaigns.ford-trucks.net/cam...s&bannerid=125
Check them out. Between all the sponsors you can get alot of different brands and face styles.
Joe
Old Feb 2, 2006 | 05:59 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome dfwf250 to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Feb 2, 2006 | 06:07 AM
missouguy's Avatar
missouguy
Check this guy out. I got my Isspros from him. Great gauges with the green bulb covers look just like stock. They supply everything including wiring. Took me about 4 hours. Piece of cake. EGT, Boost and Tranny Temp.
www.kensperformancesolutions.com
Frank
Old Feb 2, 2006 | 07:49 AM
cangim's Avatar
cangim
I got mine from egauges.com, if you want white face check out my gallery for pics. All four, pod, paint and delivery for 315.00. Autometer Phantoms, however there are many out there to choose from.
Old Feb 3, 2006 | 12:38 AM
dfwf250's Avatar
dfwf250
thanks...
I want to thank everyone for replying...i found the gauges and pod for $256.00 shipped.....three gauges by autometer and pillar....one more question...how do I paint that pillar..to match my interior....prime and the paint...or anything else special that I need to do..
Old Feb 3, 2006 | 12:40 AM
missouguy's Avatar
missouguy
I was lucky and had a friend that manages a body shop and he did it for nothing. Any body shop will take your paint code and get a perfect match. The stealership can also do it.
Good Luck and enjoy the gauges.
Frank
Old Feb 3, 2006 | 02:05 AM
1L243's Avatar
1L243
I have not done it yet but I found this guys web site very informative... You could substitute the gauges for the ones you want.
http://www.eurekaboy.com/f250/apillar.htm
Doug
Old Feb 3, 2006 | 07:29 AM
cangim's Avatar
cangim
Get a can of spray paint that is ford color matching, then spray it a whole bunch of time, I used about half a can on mine, doing about 12 light coats on it. The key is to do light coats.
