Battery size (Group)?
Old Feb 1, 2006 | 09:48 PM
GeneStoner's Avatar
GeneStoner
What is the battery size used on our trucks (Group size)?
Mil1ion's Avatar
Mil1ion
the correct answer is : 27F
Although they now don't seem to make the Ford version (F) anymore.
It is strictly 27 now.
Old Feb 2, 2006 | 07:49 AM
User 71024's Avatar
User 71024
I generally run a pair of the 27 series deepcycles with the stud and wingnut connectors, they're easier to clean, quick to remove, and if you have a boat or RV you can rotate them with your boat batteries that generally get abused. You can also pull them out quickly if you need a portable 12 volt suppy and can't reach it with jumpers.
Old Feb 5, 2006 | 02:23 AM
busted knuckle's Avatar
busted knuckle
i second the marine terminals never use anything else again
Old Feb 5, 2006 | 02:26 AM
busted knuckle
hey quick tip the bolt that goes through the terminal has the same thread as the wing nut so (And starter sol.) so get 2 small extra nuts and thread them on right behind the nut on the battery bolt. so if you lose any nuts off the connections you have one right there. it will save your butt
Old Feb 5, 2006 | 07:35 AM
User 71024's Avatar
User 71024
Words of wisdom from someone who has dropped his nuts more than once
Old Feb 5, 2006 | 11:57 AM
jrsroadhauze's Avatar
jrsroadhauze
Twin Diehard Gold group 65s. Built new battery box pans and mig welded to orginal mouting brackets.
Old Feb 6, 2006 | 03:52 PM
tomcasino's Avatar
tomcasino
I found some great military style battery clamps at www.pullpal.com
