HELP I'm stuck!!!!
Old Jul 9, 2001 | 05:57 PM
1ole4d's Avatar
1ole4d
HELP I'm stuck!!!!
My 78 F-150 is stuck in 4wd! I can't get the lever to move out of 4L or 4H. What could be causing this?? When I try to drive it in 4H the rear tires lock then unlock, lock, and unlock etc etc. What in the world. ANY help or suggestions would be greatly appreciated. Oh...I have a NP205 Trasnfercase and a NP435 Transmission with the granny first gear.
Old Jul 9, 2001 | 07:32 PM
brown 4x4's Avatar
brown 4x4
HELP I'm stuck!!!!
It might just be the drivetrain binding up. Try rocking it back and forth with pressure (not forcing) on the 4wd stick. It should pop right out at the point where there's no binding between the front and rear.
Old Jul 9, 2001 | 10:54 PM
MEPHISTO_XES's Avatar
MEPHISTO_XES
HELP I'm stuck!!!!
Going into reverse for 10' or so got me out of that shape once.
Old Jul 10, 2001 | 05:25 PM
1ole4d's Avatar
1ole4d
HELP I'm stuck!!!!
But what would be causing the rear tires to lock up and unlock while it's moving? that's what has me the most concerned about.
Old Jul 10, 2001 | 09:03 PM
RubberDuck's Avatar
RubberDuck
HELP I'm stuck!!!!
Worse case senario, Broken teeth on the ring gear. Take the drive shaft off, jack it up and give'em a spin. No snap crackle or pop, you can rest easy. Okay now that you have the rear jacked up and on jack stands, go ahead and jack the front up. Now that none of the tires are applying presure to any drive train components, try to unlock the hubs, if they unlock, you should be able to shift out of 4wd. Or vice versa. The key is to not have any kind of a bind. The best place to shift in and out of 4wd, is where you can roll to a stop in neutral, and not have the truck want to roll. (flat ground) Or it could all be as simple as bent linkage and the transfer case is half in or out of a gear and causing the rearend to buck. Hope that helps
RubberDuck
Old Jul 10, 2001 | 09:07 PM
RubberDuck's Avatar
RubberDuck
HELP I'm stuck!!!!
89F250_7.5
Nov 24, 2014 12:43 PM
61steven
31
May 9, 2014 11:31 AM
speakerfritz
Oct 25, 2013 04:49 PM
blackjack33
1978 - 1996 Big Bronco
31
Sep 10, 2013 12:24 PM
darrin1999
Sep 23, 2006 09:37 PM
