92 Explorer fuel filter fight.
Old Feb 1, 2006 | 04:15 PM
afinepoint's Avatar
afinepoint
I did a search on the subject of replacement. I am not sure of the "tool" that is being refered to. I have the inlet and outlet clips out of the way. Leverage is a problem but it doesn't want to come off.
Do the fuel lines grab the shoulders on the filter? The pressure has been bled off. Is prying a danger?
Reg
Old Feb 1, 2006 | 08:15 PM
afinepoint's Avatar
afinepoint
Are the fittings like AC lines? A circular spring locks the filter and line together?
Reg
Old Feb 1, 2006 | 09:06 PM
budman-mo's Avatar
budman-mo
I can only suggest shooting penetrant in there and work on it.
I think the o-ring gets stuck more than the spring. You get your spring tool on there and are sure it's released but it's still stuck.
Old Feb 1, 2006 | 09:31 PM
JerrySimm's Avatar
JerrySimm
Yes, they are like AC lines. You'll need the fuel filter sping tool to remove them. You can't just pry them off (without destroying something).
Old Feb 2, 2006 | 04:29 AM
afinepoint's Avatar
afinepoint
Thanks men. I glad I wasn't up for much of a fight yesterday. Something told me to keep looking at it.
When the fitting is broken is there much spillage w/o elevating the truck's front end? The tank is about 1/2 to 3/4 full. I'm thinking about running the tank down if there's going to be a real problem.
Reg
Old Feb 2, 2006 | 07:15 AM
AlfredB1979's Avatar
AlfredB1979
I would guess IF you've bled the pressure from the fuel pump on forward (not the "pop off the gas cap" way of doing things...), you will not have issues with spillage.
I can't see fuel getting past the fuel pump and if you've pulled the fuel pump relay and cranked the line dry, you should be set.
Old Feb 2, 2006 | 09:13 AM
budman-mo's Avatar
budman-mo
Just keep your trouble light far away or you might have alot of trouble.
A dealership I used to work at burned to the ground because a fuel filter change sprayed gas on a trouble light. That's why they call them trouble lights.
Old Feb 2, 2006 | 10:43 AM
Exploder02's Avatar
Exploder02
Pull the fuel pump relay and crank the engine over a bit, to relieve the pressure. Also, go get the fuel / AC line tool from a local auto parts place, they'll know what you're asking for... make sure you get a METAL tool.. the plastic ones suck.
Old Feb 2, 2006 | 04:34 PM
afinepoint's Avatar
afinepoint
Exploder,
Got the metal tool from the parts store and I had a go at it this evening. The engine side is not budging. I relieved pressure by braking line at the engine. I haven't tried the inlet side yet. The store warned me about the delicate metal fingers holding onto the filter. Damage those he warned and it's a new fuel line. Can a penetrant be used on the fittings?
I let it go for now. Tiring work day. A few brain cells of common sense won out. Fatigue, cold, gasoline, fragile parts and frustration are not a good combination. Especially with the furnace cycling on and off ten feet away. Yesterday I was using a floor fan to blow fumes away and out of the garage doorway.
Will continue tomorrow or the weekend. Will have someone stand by with a fire extinguisher and remote operation of the fan - again.
That'll be my safety plan.
Reg
Old Feb 2, 2006 | 05:54 PM
budman-mo's Avatar
budman-mo
As I said before, soak it down try and get some penetrant into the fittings it will help.
I do it that way everytime just to help keep it in good shape.
Old Feb 2, 2006 | 07:48 PM
afinepoint's Avatar
afinepoint
That you did Bud. I am tired.
I'll give it a shot tonight.
Reg
Old Feb 3, 2006 | 05:24 AM
marragtop's Avatar
marragtop
If you are doing this repair in an enclosed area 10 feet from a furnace with a cycling flame, a fire extinguisher won't help you very much. If the gas fumes ignite, you'll need a lot more than a fire extinguisher. Be careful!!
Old Feb 5, 2006 | 10:04 AM
afinepoint's Avatar
afinepoint
Fuel filter 2 Me 0.
I put things back together. The filter is not coming off and the thought of a unisolable (indoor) fuel leak is not comforting.
This is one for the garage or warm weather whichever gets here first. I've replaced everything on this truck from the radiator to the heads to the entire rear but one little filter . . .
Reg
crestfallinman
Sep 22, 2019 04:00 PM
97REDPSD
Nov 30, 2007 01:05 AM
itsafordguy20
Jul 31, 2007 10:51 AM
Iceman31
20
Apr 11, 2006 09:34 PM
cotoole
Sep 30, 2001 10:35 PM
