gauges
Old Feb 1, 2006 | 10:35 AM
fordguyforlife's Avatar
fordguyforlife
gauges
i have the gauge cluster without the tachometer. it sucks. i would like to put in the stock gauge cluster with the tachometer ( i dont really want to mount an aftermarket tach on the dash). as far as i know i need to purchase one and have the dealership code in the pats system to be compatable with my truck. is that all or is there anything else.?
Old Feb 17, 2006 | 03:48 PM
javi2001's Avatar
javi2001
I'm not sure, but fallowing the Ford designers behaviour for years, probably just need install it inside cluster. There is no need for additional wires or computer setup, everything should be ready.
Old Feb 24, 2006 | 12:15 PM
fromme87's Avatar
fromme87
if you have a digital odometer, you can use that as a tach. just search the forums.
Old Feb 25, 2006 | 01:09 PM
tula771's Avatar
tula771
Using the digital tach is easy, but you have to press the button about 18 times each time you start the truck.
Old Feb 26, 2006 | 01:09 PM
fordguyforlife
i've used the digital tach before but its just to much work to setit ever time i start the truck and, it shard to glance at and read fast.
