302 has trouble running
Possibly you removed a sensor that's needed to keep this thing running properly, or you have a fuel delivery problem. But I'm not sure about running a CFI system in a derby car. A good impact that damages part of the control system could knock you out early. I'd yank the throttle body and all injection engine controls off and stick a two-barrel carb on, it'll bolt right to the manifold. You might have to use an aftermarket electric fuel pump designed for use with a carb though, as some of the CFI systems are high pressure and the CFI pump wouldn't work with a carb. Even the low pressure systems are still too high, about 14-16 psi where a carb needs about 3-7 psi. A FP regulator might cut that down enough.
Another possibilty occurs to me...did you remove and bypass the Inertia switch in the trunk? If not, you may have triggered it while working on the car and aren't getting any power to the fuel pump. It definitely needs to go away if you do stay with the CFI system, or the fuel pump will shut off the first time you take a hit...or hit someone else.
How long do you have till the derby?
I was wondering about your idea of replacing the throttle body and all injection stuff with a two-barrel carb. How much do one of those normally run new/used? We already have an electric fuel pump attatched becuase the stock in-tank fuel pump would not work outside the tank. The fuel kept it cool inside the tank. Outside, it was getting way too hot.
And by the way, the earliest derby we have entered isn't until June 17, so we have some time to work with the problem.
Okay, it's pretty much what I thought. CFI or TBI...Throttle Body Injection. Ford calls it CFI for Central Fuel Injection. I have one on an '84 Town Car I'm stripping down.
I'm still curious about the "choke" though...
So what are you using for a fuel pump? If it's an off-the-shelf aftermarket unit designed for use with a carb, then it's not supplying enough pressure for your CFI. I'd have to look it up to be sure but I think yours is the high pressure CFI which needs around 40 PSI.
Anyhoo, you could pick up a 350 or 500 CFM Holley used, the 500 should go for about 100 bucks (around here anyways since it's the designated carb for almost all classes at the two local tracks) and you could probably pick up a 350 CFM for 50-75 bucks. Another alternative, one that might find for free, is the Motorcraft 2bbl that came stock on so many Fords. Look for one on an early '70s 302, so it's already jetted pretty close.
About the choke, that is what our diesel mechanic said. When he was working with it, he was playing with two different things under the hood while I was in the car starting it for him. I'm not to familiar with this kind of thing, although I do know how it works and operates. You might be right in saying that there is no choke. I think that he should probably stick to his diesels, lol.
For the fuel pump, we went to Carquest and bought an out of the tank electric fuel pump. I believe that this is producing enough pressure becuase we are getting fuel to the injectors and it fires up everytime we try. Does that mean anything?
Thank you for all of your help so far and for any more that you might wish to add.
