Clutch Size?
Old Jan 31, 2006 | 11:22 PM
SMS888's Avatar
SMS888
Clutch Size?
I'm trying to figure out my clutch size before I go to replace it. I have an 84 F150 4x4 shortbed with a hydro clutch. Is the disc a 10 or 11"? Im pretty sure its a 10" but no positive. Also, does anybody have any opinions on what temp. thermostat i should use? i was looking to switch to a lower temp, like a 180deg, should i stick with a 195deg? Thanks a bunch fellas.
~Sms888
Old Mar 27, 2006 | 01:57 AM
theophage's Avatar
theophage
10" is stock clutch size for your truck
Old Mar 27, 2006 | 07:15 AM
mr clutch's Avatar
mr clutch
I believe after 1980 the flywheel is drilled to accept either the 10 or 11 inch clutch
Old Mar 27, 2006 | 08:21 AM
jmteam6's Avatar
jmteam6
You can use either a 10" or 11" clutch around here an 11" is cheaper than the 10" by 10.00. I use a 160 degree thermostat in the summer and a 180 degree in the winter just because I use it for heavy hauling all the time.
Old Mar 27, 2006 | 11:04 AM
theophage's Avatar
theophage
www.rockauto.com sold me a 10" clutch for $95 plus shipping
