General Automotive Discussion
problems with truck
Old Jan 31, 2006 | 11:19 PM
Jason7396's Avatar
Jason7396
problems with truck
well i did't put the aftermarket tach in yet and i got a factory cluster with a tach and its from the same year and i put it in with the speedo that was in the cluster when i bought it in and it will idle up but when i push in on the clutch and shift in to 1st or reverse it wants to die and it sputters but i put my factory cluster back in it and it worked fine and i put the new one with a tach back in it with my speedo (thought the little millege computer was killing it) and it wants to die again is there any thing i can do or is it just better to put the factory cluster that came in my truck back in it and put the aftermarket tach in
its a 95 f150 with 4.9 and 5 spd and the new cluster i got was from a 95 i know it is cause i pulled it out of the truck
now i cant get it to run with factory cluster just wants to die when put in gear and let out on clutch and just sputters and dies
ANY IDEAS
<!-- / message --><!-- no sigs except when logged in -->
Old Feb 1, 2006 | 12:12 AM
Bdox's Avatar
Bdox
Sounds like the tach is not hooked up correctly. You will need to check a wiring diagram.
Old Feb 1, 2006 | 08:33 AM
Jason7396's Avatar
Jason7396
can someone please help me with this i have tried everything does any one have any ideas just want to put old cluster any ideas why its not running right
