Cold start, while waiting for:
A. CTS to indicate thermostat opened.
B. O2 sensor to be warmed up.
C. Wide open throttle (It's supposed to be 90% of TPS, however I've seen it higher or lower depending on the vehicle).
It will really depend.
It will be calibrated on throttle opening).
But it is surprising early - anything over 70-80% throttle (irrespective of rpms) with throw it into open loop...
So, whenever you may want to use it (i.e at WOT) you can't...
