The motor is hard to turn over when the truck has been running. Is my starter getting heat stroke? I have a 90 F350 with 460EFi. I cleaned all the grounds to the battery and the starter.
i would replace both positive and negative cables. even if they look ok im sure they are original equipment. go to a 1gauge as well. are you running headers ?
i would still look into replacing the battery cables. you would be amazed at what a new set will do not only for starting but for your entire electrical system.
I would also look into a heat shield or wrap for that starter. i imagine its getting far to hot and causing some of this issue as well.
