no speedometer
Old Jan 31, 2006 | 04:06 PM
roadsaw's Avatar
roadsaw
no speedometer
hello everyone I am new to the fourm glad to be here. The speedo stopped working and the ABS and check engine light came on all at the same time. 1999 F-250 4x4 diesel please help
Old Jan 31, 2006 | 04:15 PM
Betthebux's Avatar
Betthebux
Typical symptons for bad VSS Costs just over 20 bucks at a dealer. Sometimes you can clean them and they will work but that didn't work for me.
Old Jan 31, 2006 | 04:32 PM
pclark76's Avatar
pclark76
I had same problem. Ended up being a wiring harness behind dash fuse box was loose.
Old Jan 31, 2006 | 05:34 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome roadsaw to Ford Truck Enthusiasts!
We are happy you have chosen the best source for Fords.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Jan 31, 2006 | 07:30 PM
Powerstrokedlariat's Avatar
Powerstrokedlariat
Welcome to the club, it is your VSS sensor, it is located on the top of the rear differential, and I believe it is one 10mm bolt. For just over $20 as mentioned earlier, I dont think it is worth cleaning it, just change it out. Very common. Lets us know if that fixes it!
Old Jan 31, 2006 | 09:45 PM
guzzle92's Avatar
guzzle92
I just picked up a new VSS today due to some weird codes I am getting when I stomp on it. Related to VSS and overhead console?? Anyway, called 3 dealers and all of them quoted $22.72. It should only take 10 min and a 10mm socket unless you're like me and had some difficulty re-starting the 10mm bolt. Had lots of locktite on the threads from the factory and kept trying to cross-thread. Wire wheel on the bench cleaned up the bolt and went right back in, just cost another 10min.
