tailgate logo
Old Jan 31, 2006 | 01:57 PM
chris12's Avatar
chris12
tailgate logo
OK so when you remove the ford emblem on the tailgate and there are three holes. What did everyone use to fill the so you can paint over them. i was told weld the hole shut. then smooth the welds out then paint. but before i paint should i put some bondo on or anything
Old Jan 31, 2006 | 02:00 PM
amish77's Avatar
amish77
as long as the welds are smooth enough you won't need any bondo. The bondo should only be used to smooth out any imperfections you didn't get while grinding.
Try skinning the whole panel with bondo, and seeing what comes up when you sand it down looking for low spots. As long as your welds aren't too high and they didn't warp the surrounding metal, you won't need a thing just fo fix them for paint
Old Jan 31, 2006 | 02:33 PM
chris12's Avatar
chris12
so i can put i bit of bondo on and sand it down so it ends of being all flush again before i paint..
Old Jan 31, 2006 | 06:01 PM
el conquistador's Avatar
el conquistador
you can try brazing the holes with copper or aluminum
Old Jan 31, 2006 | 08:37 PM
Ken00's Avatar
Ken00
You should end up sanding off almost 99% of the bondo when your done if the metal work was done properly.
Old Feb 1, 2006 | 04:38 PM
amish77's Avatar
amish77
yeah I'm with ken. The skinshould come off for the most part.
