Gibbs is pretty slick!
Old Jan 31, 2006 | 11:18 AM
yechave's Avatar
yechave
I heard about Gibbs penetrating oil from a lock smith that used it to open very old safes. Said it was great for guns and anything on cars, lubing drill bits etc. The first batch I bought was so slippery, it leaked from every seam and orifice in the can. A few years later, they refined the containers, and I have yet to see one leak. This stuff is absolutely amazing. The only problem I encounted was, I used it to lube my door hinges, and after a couple of years, I found the hinges had moved on the frame of the car! Had to take it to a body shop to reset the hinges. So, I still use it, but far more carefully. Great for keyholes, trigger assemblies, linkage, you name it. Best oil I've ever seen! Hardest part was finding a dealer who sells it.
Old Jan 31, 2006 | 11:33 AM
fred_79f250's Avatar
fred_79f250
Double-D 40: the penetrating oil for well endowed women.
Old Jan 31, 2006 | 11:46 AM
scole250's Avatar
scole250
Is Gibbs a lubricant or solvent? If it's like WD-40, it's a solvent and should not be used as a lubricant. It's been mentioned here before though. Of course, that was too late to save my dirt bike chain and sprockets when I was a kid. What happens if use WD-40 as a lubricant on semi-automatic handgun or rifle?
Old Jan 31, 2006 | 11:58 AM
furball69's Avatar
furball69
it'll probably work great for an hour then jam up.
Old Jan 31, 2006 | 12:06 PM
NH-Hottie's Avatar
NH-Hottie
Sounds almost like the oil my mother used in her industrial sewing machines. I don't know the name, since she would bring a glass jar of it home from her work. The stuff would leak all over the place if you tried storing it in a regular oiling can. She kept it in a jar, and used a glass dropper to put it in her machines. Good stuff. The lubrication lasts for a very long time. I remember my dad always getting yelled at by my mom, when he would 'borrow' some for his tinkering.
Old Jan 31, 2006 | 03:40 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Gibbs works great, my brother-in-law sells it wholesale as marine supplies.
It does contain a solvent, I think there's at least alcohol in it now, used to be Xylol.
But boy does it break apart rusty things!!!
Old Jan 31, 2006 | 03:42 PM
krewat's Avatar
krewat
Oh, by the way, it is really for penetrating rust, but the oil that remains after the solvent evaporates is very much like ATF.
Old Jan 31, 2006 | 04:10 PM
mwtmwt's Avatar
mwtmwt
I am having trouble with a bolt on a manifold.
Been soaking it in pb blaster for a couple of days.
No luck
Do you think this could go beyond pb blaster for penetrating
Thanks
Old Jan 31, 2006 | 08:24 PM
krewat's Avatar
krewat
No luck
Thanks
It's worth a shot.
It has a solvent in it that makes the oil VERY thin, so it can get into the rust. I've been amazed quite a few times.
nobodyspecial
Nov 4, 2007 01:51 PM
3/4ER
Aug 2, 2005 01:48 PM
pchristman
13
Oct 3, 2004 12:17 PM
ranger rules
16
Feb 16, 2004 10:03 AM
jor
34
Jan 1, 2004 07:47 AM
