Will a 5 speed tranny off a 460 fit on my 7.3L IDI. And will a transfer case off a 94 250 7.3L IDI E4OD bolt onto that 460 5 speed. Thanks for all the help!
Transfer Case may bolt up but I would check the yokes/U-joints. I noticed that the diesels have a tendency to use larger U-joints (more torque at lower rpm) or if they are the same there is a good chance they will be the weak link in the system.
